Welcome aboard! I'd suggest you get aqainted with the search button as many of these topics have been delt with before.
At glance, I guess your distributor cap is full of water.
Remove the cap, spray it with electronic contact cleaner, I suppose brake cleaner may be OK on the CAP only. Allow it to air out if you find moisture droplets. Clean and dry the spark plug wires if still damp.
Unless you held the water stream at an open port or hole, I doubt a quick wash filled the engine to a point that running for 5 minutes wouldn't clear it out.
