1mz-fe coil packs, engine misfire dtc p0300, p0301, p0302, p0303, p0304, p0305, p0306 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2010, 11:26 AM   #1 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
4th Generation 1mz-fe coil packs, engine misfire dtc p0300, p0301, p0302, p0303, p0304, p0305, p0306
I think this TSB says allot as it offered coil pack replacment under warranty for certain vehicles. ** Don't get excited folks, your warranty is done gone by now. ** This is simply acceptance that there was an issue and some coil packs may not last as long as others.
If you found this article and you are here for one of the Misfire Codes, this is not inclusive to say "its the Coil Pack!" I posted this as a guide to Not Discount that the coil packs could be causing the issue, OK!
{{PASTE}}
From: http://www.camrystuff.com/manuals/Ge...neous/TSBs.pdf,
From Page 349 of 356
M.I.L. ON" 1MZ-FE ENGINE MISFIRE DTC P0300, P0301, P0302, P0303, P0304, P0305 OR P0306 Models: Applicable Avalon, Camry, Sienna & Solara
  • Technical Service BULLETIN April 28, 2004 # EG008-04
Introduction: Some vehicles equipped with 1MZ–FE (V6) engines without VVTi may exhibit a rough idle and/or a M.I.L. “ON” condition with a diagnostic trouble code or codes for misfire caused by an improperly operating ignition coil assembly. Production changes have been implemented to prevent this condition from occurring.
Applicable Vehicles:
  • 2001 model year Japan built Camry vehicles equipped with 1MZ–FE engines (V6).
  • 1998–2001 model year North American built Camry vehicles equipped with
  • 1MZ–FE engines (V6)
  • 1998 – 1999 model year Avalon vehicles.
  • 1998 – 2000 model year Sienna vehicles.
  • 1999 – 2002 model year Solara vehicles equipped with 1MZ–FE engines produced BEFORE the Production Change Effective VIN shown below.
Solara 1MZ–FE 2T1CF2#P*2C578710
Applicable Warranty*:
This repair is covered under the Toyota Federal Emissions Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date. For California specification vehicles registered and operated in California, Maine, Massachusetts or Vermont, this repair is covered under the California Emissions Warranty, which is in effect for 36 months or 50,000 miles, whichever occurs first, from the vehicle’s in-service date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
{?} I'm not sure why it lists only the Solara VIN!
73sport is offline   Reply With Quote
Old 07-29-2010, 08:36 PM   #2 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
That's not good. I remember reading this, but I didn't have my engine's VIN number on hand. Now that I do, my 2000 Solara motor falls within the affected VINs.
I'll keep an eye on mine. My motor only had 72k miles on it. The internals are now about 750 miles after my rebuild, but the ignition components are original.
For the record, I have the Diamond coils, not Aisin coils.
The two part numbers I could find are:
90080-19012 (Diamond) and 90919-02215 (Aisin).
So, it appears the Diamond made coils are affected.
Also, Toyota no longer sells Aisin replacements. They're all Diamond coils now. 90919-02215 has been superceded by 90080-19012. So, hit the junker if you want Aisin coils, but that's risky too. The coils list for around $80-90, so you're looking at about $300 for all three. The Diamond coils have higher internal resistances, so they do produce stronger spark, but they also get hotter.
Both are Japanese companies, but the Diamond coils are made locally.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 07-30-2010, 01:56 AM   #3 (permalink)
V8'sRGone
73sport's Avatar
Chris, theres a little bit something for everyone in that link you dropped us! This one was too big to let slip by so I posted it. I wish it had an index. All kinds of stuff in there!
Most of it did not include 95's tho! But I don;t beleive that clears all 95's of issues. Its just not there in that TSB, prolly in another somewhere else!
Hopefully yours doesn't bite you, but I'd grab em from the bone yard while they're avaialable or pay the piper brand new!
Tags
1mz-fe, coil, misfire, p0300 p0301-p0306
