I'd venture to guess the final output circuit (amp) has a faulty component. Electronic components fail for having leakage when no input is applied which is likely the case here. Ahead of the amp is a power supply which has capacitors holding a current which was previously driving the amps circuits. When the input is cut off, the output should be zero. In your case it's not. Here is how you can test that.
I'd measure the voltage across the speakers input in DC volts and have someone turn it off while in use just as you normally use it and listen to it volume wise. If the meters reads a positve number (assuming you have the polarity correct) and you get like 3 plus volts contineous until the sound is gone, the amp is likely going bad. Direct DC applied to a speaker will kill it over time so be advised that it could kill again.
