1MZFE overheating! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2010, 10:58 PM   #1 (permalink)
flex1016's Avatar
View flex1016's Photo Gallery
1MZFE overheating!
my car just started overheating, when i add fluid and start the car when it gets warm it starts spitting water out of the resivor? i get under thecat and i dont see any leack or nothing ..i thinking its the thermostat
what eles should i check for?
and what does it mean when water spitts out scavanger system?
flex1016 is offline   Reply With Quote
Old 07-30-2010, 10:59 PM   #2 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Radiator cap
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 07-31-2010, 08:33 AM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I think your initial thermostat guess is right. Sounds like it may not be opening. Has the water pump ever been changed on the car? What's the condition of the radiator?
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 07-31-2010, 09:39 AM   #4 (permalink)
4th Gen Camry Fan
View hardlymoving's Photo Gallery
Water spitting out the reservoir? You most likely have a blown head gasket. Sorry to be the bearer of bad news. Overheating will destroy head gaskets and warp your heads. You can try a fix with a product called K-Seal sold at NAPA for $15. To get an idea on what's involved to fix it, you can checkout this website I wrote replacing one on a Honda Accord:
http://hondarepair.intuitwebsites.com/Page-1.html
hardlymoving is offline   Reply With Quote
Old 07-31-2010, 12:26 PM   #5 (permalink)
Nervous's Avatar
Do not scare the OP without good reasons. I just recently had the similar issue and the problem was in two things - radiator cap and thermostat (I installed it backward ; the same effect as it doesn't open). So, check these two things first.
The Following User Says Thank You to Nervous For This Useful Post:
projektvertx (07-31-2010)
Old 07-31-2010, 01:59 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Simple things first. Inspect and or repalce the radiator cap. It could be that simple!
Next time you park it, park it somewhere where the passanger side of the car is higher than the drivers side. When it cool, take up to an hour and just keep topping off the fluid level at the radiator cap. Start it long enough to move some air about (20 seconds). Turn it off. Keep topping it off. Install new cap and tell us what happens.
Hint; any defects, tears, cracks, chunks, or debris in the caps two rubber seals can make it puke into the tank.
Oh - to answer the "why"
Your car has a 16lb cap. When water heats it expands, if the expansion exceeds the pressure rating of the cap, it allow the water to vent to the tank so it the system does not damage things like hoses and radiators. But a bad cap can let everything out at 1lb making it LOOK like your car is over heating when all it really is is a bad cap! The cap also allows water back in to the system when the water cools. Again, a bad cap can cripple both of these important functions!
73sport is offline   Reply With Quote
Old 07-31-2010, 02:04 PM   #7 (permalink)
View aznstylez's Photo Gallery
Probably a cracked radiator also.
aznstylez is offline   Reply With Quote
Old 07-31-2010, 02:10 PM   #8 (permalink)
V8'sRGone
73sport's Avatar
Thumbs down
Definitely, replace the radiator! NOT!!!!!!!!!!!!!
Originally Posted by flex1016 View Post
i get under the car and i dont see any leak or nothing ....
Old 07-31-2010, 08:32 PM   #9 (permalink)
View oldfirebird's Photo Gallery
Does the heat work? If you get no heat, the water pump isn't moving water.
If the heat does work, I'd blame the thermostat first.
When the car's hot, is the upper radiator hose hot too, or does it stay cool? If it's overheating you should have a hard time holding on to it for more than a few seconds. If the thermostat never opened, it'll be cool enough to hold.
If the hose is hot, shut it down and grab the lower hose. If it's hot too, you don't have enough air moving across the radiator. If it's cool, you have a clogged radiator.
oldfirebird is offline   Reply With Quote
Old 07-31-2010, 10:04 PM   #10 (permalink)
flex1016's Avatar
the cap is brand new and the radiator is brand new and has no leaks...also when i touch the upper hose it gets hot.
when i first start the car up i let the car warm up,then i drive the car for 10 min. then out of no were the water guage jumps all the way up to the top and i pull over and pop the hood and then water is just shooting out of the resivor...
i think it is the thermostat, its never been changed since i got the car..has 150k miles
Old 07-31-2010, 10:27 PM   #11 (permalink)
Nervous's Avatar
talso when i touch the upper hose it gets hot.
What is about lower hose? Is it just warm?
Old 08-01-2010, 11:50 AM   #12 (permalink)
What about the heat? If you turn the heat on high, does it blow hot air?
When the temp gauge is above half, does the radiator fan turn on?
Old 08-04-2010, 09:23 PM   #13 (permalink)
flex1016's Avatar
[QUOTE=oldfirebird;3275970]What about the heat? If you turn the heat on high, does it blow hot air?
ok, i changed the cap. now water dont spit out no more. but when i turn the heater on, i get no heat, and the cars temp is in the middle,the car is fully warmed up at this point.. and somtimes the temp moves up a little then fall back down to the middle..
im thinking its the thermostat going badwhat do u guys think ?
Old 08-04-2010, 09:30 PM   #14 (permalink)
Nervous's Avatar
So, if heater doesn't blow hot air even when engine is hot this may mean two things: water pump is bad, or there is air trapped in the system. You need to bleed the cooling system by running engine with opened radiator cap until all bubbles disappear. Put the heat on MAX, open radiator cap (when engine is still COLD!) and start the engine. Coolant will start to overflow slowly - this is ok. You may get a superfunnel like the one below to prevent spills:
http://www.summitracing.com/parts/LIL-24610/?rtype=10
Old 01-02-2012, 05:46 AM   #15 (permalink)
View camry_3.0V6_1999's Photo Gallery
Camry 3.0V6, 1MZ-FE overheating with bubbling in reservoir
1999 Toyota Camry 3.0V6, 1MZ-FE, 175k km.
Did read thru this thread - a bit different scenario, there is no coolant leaking or spilling out from reservoir.
Because of recent hot weather (Australia, summer now), 43C today. Temperature will go over 3/4 of temperature gauge approaching red line. Usually is slightly below 1/2 on gauge when it is normal. This happened when drive and stop on 60Km/h roads with multiple traffic lights, with A/C on. The temperature will drop when A/C is off. It is fine when on highway even with A/C on.
Found boiling + bubbling in the reservoir (level is 20mm above the FULL line) when parked + idled by roadside. When A/C is turning, temperature was creeping up.
Cap? hose (no leak nor crack per Toyota service)? radiator clogging? water pump? big air pocket (the red coolant was not flowing into the engine as seen thru the translucent coolant hose when bubbling)? air pressure in the radiator too high to take in coolant? cap?
Recently did a service and check, no leak on anything. Toyota service...since only they have empty slot to fill in before the holiday season.
any suggestion will be greatly appreciated!
camry_3.0V6_1999 is offline   Reply With Quote
