Originally Posted by egeorge
Hi, in my 1993 camry 3vzfe I changed the lower control arm bushings (L and R), but just after couple months they broke apart, I've done it twice in the last 10k miles. I just bought the whole control arm with bushings but before I change them I would like to find out if anybody knows why this could be happening, do not want to loose the new ones right away.
Thanks in advance.
If you pressed them in yourself, you need to orientate the inner sleeve so the arm and the mounting bolts match how they are when the car is sitting at ride hieight. Meaning; if the rubber is bonded to two surfaces and you twist one 90 degrees from the other to put it in the car at ride height, the rubber bond will fail.
Other than that, like he said, fluids attacks rubber. Stop all leaks!
EDIT: so a new complete assembly should be fine as I'd guess they aligned them for the average ride height.
