98 camry...can't figure out problem
I have a 98 camry that after driving a mile or so it will not idle. I have changed everything imagineable. engine, wiring harness, transmission, ecm, u name it i have changed it. the car will run all day at idle. I have change the air/idle sensor, vsv, cleaned the egr valve, plugs, wires, everything. I'm convinced it must be something like a short after before the ecm. I'm getting no codes. Help. I'm have too much money invested to trash, but i'm real close. any suggestions. the motor and tranny came out of a running 98. I also took the ecm and wiring harness from that same car and I am getting the same results as the last motor.
