oil leak ..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2010, 07:11 PM   #1 (permalink)
christine
cocacolagrl's Avatar
View cocacolagrl's Photo Gallery
3rd Generation oil leak .....
and my dad wont take me seriously for anything i say is wrong with the car and now something serious is going on and idk what to do.....but when my sisters car has a problem it goes to the mechanic right away..no questions asked...so i guess its gotten to the point where i have to take this into my own hands.....
can the oil be leaking from different areas???it looks like its coming from the oil pan.....is it better to replace everything and if so what will i need to buy...or is there a certain part that is causing the leak...
cocacolagrl is offline   Reply With Quote
Old 07-31-2010, 07:15 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
well if the pan is leaking that's an easy fix there is no "part" just a tube of rtv sealant run you maybe 6 dollars do it when you change the oil also pick up a new drain plug gasket, like 50 cents dangling on the self only other thing down there might be a oil pressure sensor or front/rear main seals
^ and leaving it that way!
Old 08-01-2010, 02:46 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Let the air out of your dad's tires. Then dump a quart of oil under your car that'll stain his driveway so he'll get the "severe" leak fixed.
How's the maintaince been on your car? Regular timing belt, water pump, and seals replacement? Even if it has been done recently, things can still leak (especially if you have the 4cylinder engine. It's fairly common to have some leaking.)
'07 Honda Ruckus Big Bore
Old 08-01-2010, 08:21 PM   #4 (permalink)
View Narciss's Photo Gallery
after replacing the oil pan gasket which was an easy fix, and the gasket costs like 2 dollars? my leak was cleared up. if it's not leaking from the oil pan though i'd just take it in...
Narciss is offline   Reply With Quote
