door lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2010, 01:34 AM   #1 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
3rd Generation door lock
ok long story short....lost alarm remote, so now i have to manually use key to lock/unlock doors......but i have noticed that the passenger door wont open using the key..the driver side is ok though...my question is, is something wrong with the door?? or does that happen to everyone else??? gen3
93XLEcamry is offline   Reply With Quote
Old 08-02-2010, 09:08 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
more so now i have been noticing it being difficult to unlock my driver door with the key.. i would think its the lock cylinder
you try removing the door panel to look at the metal links? maybe one loose
The Following User Says Thank You to abew330 For This Useful Post:
93XLEcamry (08-02-2010)
Old 08-02-2010, 09:13 AM   #3 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
One possibility...
When you turn the key in the lock, the cylinder your turning has a clip on it that attaches to a control rod that actuates the locking mechanism. If the control rod comes out of the clip, or the clip breaks, etc., then turning the key will do nothing because you're no longer moving the control rod.
Just had that problem on one of my Camrys. The control rod had popped out of the clip for some reason. I was able to take the door panel off and pop the rod back into the clip.
eddie926 is offline   Reply With Quote
The Following User Says Thank You to eddie926 For This Useful Post:
Old 08-02-2010, 05:05 PM   #4 (permalink)
93XLEcamry's Avatar
ok...i'll check to see if its the problem....btw is it a hard fix?? or its pretty straight forward???...
Old 08-02-2010, 07:58 PM   #5 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $134901
View JimBowNut's Photo Gallery
I see that all the time.
As a T. Parts Counter Jockey i have people come in all the time w that issue.
Most of the time a new key made from T. Key Code takes care of that situation.
Most times. Sometimes you must replace the lock cylinder. And it doesn't come keyed to your vehicle. So you should ask what locksmith the dealer uses. It will save some headache calling various locksmiths.
Ask at the parts counter. The service department has no interest in helping you to do it yourself.
JimBowNut is offline   Reply With Quote
Old 08-02-2010, 08:11 PM   #6 (permalink)
RIBMIESTER
JimBowNut's Avatar
OK....I looked for a transmitter remote for gen3 and cannot find that in reg. T. EPC.
I'm wondering if your car came w that remote? Or if it was an aftermarket job.
If T.brand the it was ordered w the car as an accessory, anyway I was just trying to find the
T. part #.
J.
The Following User Says Thank You to JimBowNut For This Useful Post:
93XLEcamry (08-03-2010)
Old 08-03-2010, 10:03 AM   #7 (permalink)
93XLEcamry's Avatar
T. part #.
J.
yep...came with car
