2001 Camry brake indicator light on dash - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2010, 09:38 PM   #1 (permalink)
View red73mustang's Photo Gallery
The stupid light will not go off and she's over due for NJ inspection!!
This is what I checked so far:
Fluid in master is topped off
replaced both rear brake bulbs
re seated 3rd brake light bulb and insured it lights up
I searched the forum with no real luck.
Could the shoes in the rear brakes make the light stay on?
Help!
red73mustang is offline   Reply With Quote
Old 08-03-2010, 10:26 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
make sure your parking brake isn't too tight so it drags the rear shoes always. how many clicks on parking brake handle before car stops moving in D ?
another option, you have a dragging caliper/drum ?
Old 08-04-2010, 02:17 AM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
If everything is working fine...just remove the bulb. It'll pass inspection at least.
Just do weekly walks around the car and check to make sure the bulbs are working and it's not an issue :thumsbup:
Chris Crash is offline   Reply With Quote
Old 08-04-2010, 07:42 AM   #4 (permalink)
Thanks for the reply s, I remember that this light came on right after I replaced the front pads so I will take a look at the calipers.
