97 2.2L Oil Leak Pics - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2010, 09:14 AM   #1 (permalink)
View kjarrett's Photo Gallery
Hi folks, my trusty '97 LE has developed an oil leak (or two), would you have a look at the pics in this set and let me know what you see? TIA!
http://www.flickr.com/photos/kjarret...th/4866186460/
Here's an example:
'05 Rav4 L
'97 Camry LE
kjarrett is offline   Reply With Quote
Old 08-06-2010, 09:22 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863210
View BamZipPow's Photo Gallery
I'd guess the valve cover gasket...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 08-06-2010, 01:14 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i concur with bamzippow. its really the only thing that can leak on the back of the motor.
Old 08-06-2010, 01:53 PM   #4 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
That could be a distributor leaking too. But IIRC yota eliminated the distributor stuff from 97 5SFE onwards? IDK...gotta check out the Gen4 5SFE manual. If this engine doesnt have a distributor then could be a VC for sure...easy fix (~$30 max), lots of DIY's stickied on this forum have the information.
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 08-06-2010, 02:16 PM   #5 (permalink)
Awesome, sounds like something I can tackle! Just did an alternator, was so proud of myself.
Found this: How-To Guide: Removing and Painting a Valve Cover - 5SFE -- 56K warned Lots of Pics
But it is missing a lot of pictures. Is it complete and correct with what's shown?
Looks easy...just those four things holding the cover on?
-kj-
'05 Rav4 L
'97 Camry LE
Old 08-06-2010, 04:19 PM   #6 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Might be the oil pan gasket.
Chris Crash is offline   Reply With Quote
Old 08-06-2010, 05:57 PM   #7 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
If that's oil, I would also first guess valve cover gasket (as others have said). But what fluid have you been losing (or having to add)? I ask because that area looks like it could be in the runoff path of either of your transmission seals too (that surround the CV axle). Does the fluid have a reddish tint at all (ATF) or just brownish/black (oil)?
ycartf is offline   Reply With Quote
Old 08-06-2010, 09:58 PM   #8 (permalink)
View 1996camry's Photo Gallery
I'm not sure if 97 model has distributor or not. If 97 model has distributor, then the O-ring of distributor is leaking. Also, the cover head gasket can be leaked, too.
1996camry is offline   Reply With Quote
Old 08-06-2010, 10:00 PM   #9 (permalink)
97 does not have a distributor
Old 08-06-2010, 10:15 PM   #10 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i would say it is the distributor hole on 97 4cyl
even though on 97 and later camry 4 cylinder, toyota use distributorless ignition
the valve cover still has that hole there, and it is plug by a plastic cap, and can leak.
double check the half moon on the valve cover as well.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 08-07-2010, 09:01 AM   #11 (permalink)
Well I just checked and there is definitely some oil on the back side of the engine beneath the valve cover in a couple of spots. So I guess that is good news.
I am going to wait and see what the oil analysis says. If there is no coolant in the oil or other major problems I'm going to do the valve cover gasket myself, clean the engine really well, and see what happens.
If the analysis comes back as I expect it to, confirming coolant is present, then we've got a whole new set of problems... :/
-kj-
'05 Rav4 L
'97 Camry LE
Old 08-07-2010, 03:16 PM   #12 (permalink)
Ok, if 97 model doesn't has the distributor. Your car used coil pack, right. trace the spark plug wires and it's connected to coil pack. behind the coil packs, it's known oil leaks because there is half moon sit under the valve cover. when you remove the valve cover, on the driver side. it has 2 half moons sit under the valve cover. take those out and clean really good with collaborator can. reseal silicon to the half moon and put it back.
my 2000 toyota camry, the half moon leaks on me. the oil drops down right side on the driver side. you can see oil drop down on the transmission and travel down to the oil pan. if you take your fingers and try go under the coil packs to see if you can detect oil leaks or not.
WARNING!!! MAKE sure the engine is turn OFF and ENGINE is cool when you try to put your fingers under the coil packs.
Old 08-07-2010, 03:28 PM   #13 (permalink)
Thanks, it's oil, I've been having to add it but the ATF is fine.
Would love a pic of these half moon things!
-kj-
'05 Rav4 L
'97 Camry LE
Old 08-07-2010, 03:45 PM   #14 (permalink)
download the manual for your model
download the pdf "engine section"
http://www.camrystuff.com/index.php?page=Gen4_Manuals
The Following User Says Thank You to 1996camry For This Useful Post:
kjarrett (08-07-2010)
Old 08-07-2010, 06:07 PM   #15 (permalink)
Couldn't find any reference in the PDF that was helpful. Need to head out and take a peek I guess. Thanks anyhew!
'05 Rav4 L
'97 Camry LE
