Door part question (56k Warning) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2010, 07:17 PM   #1 (permalink)
Athlon_64's Avatar
View Athlon_64's Photo Gallery
Question Door part question (56k Warning)
Hello everyone. I'm trying to install this...
And I'm pretty much at a loss at how to get this part off.
On the backside of the door panel there is a removable plastic cover that i took off. This revealed one 10mm bolt.
I took it off but it didn't seem to help loosen the part any. I'm scared to break anything so I figured I'd ask and see if anyone else has removed these parts before. As always thanks for your time. I appreciate it.
Not Even Doom Music makes this sig cool
Athlon_64 is offline   Reply With Quote
Old 08-11-2010, 07:19 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Remove the nut, then yank on it. It's glued in I THINK.
Chris Crash is offline   Reply With Quote
Old 08-11-2010, 10:11 PM   #3 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
hey man, i tried to remove that when i was tinting my windows BUT the problem is the pins behind that.
when you remove it the pins will break down or should be very lucky...
but my pins broke and then i use adhesive to keep it in place.
you can see the black pin (left to the nut) the main problem is that.try to remove it gently.if you can take it out, it is much much better.
AliRazoR is offline   Reply With Quote
Old 08-11-2010, 10:22 PM   #4 (permalink)
Try inserting a flat blade screwdriver and gently prying up here:
Old 08-12-2010, 12:58 AM   #5 (permalink)
Athlon_64's Avatar
Thanks for the feed back guys. I'm gonna give your suggestions a shot and report back. I'm looking forward to getting these installed.
Old 08-12-2010, 02:25 AM   #6 (permalink)
chrondog
View edward blawat's Photo Gallery
as well as using some foaming glass cleaner from a can it stop the butal from resticking to the surface i haven't looked at my cam (just got it for free a month ago) but i know when i did work on a few lexus and toyota doors under the weather strip you have to drill out rivits to remove chrome trim and then rivet them back with these plastic coated rivits
edward blawat is offline   Reply With Quote
