Power door problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2010, 08:00 AM   #1 (permalink)
Gameroom cash: $120300
View johnjan's Photo Gallery
Power door problems
In my Camry 94 LE, the passenger power door does not open when inserting the key in the driver door and double turning. Also cannot lock or open the passenger pd using the driver door main controls, nor with the passenger door control.
In short, the passenger door is now manual instead of power. I can hear the clicking sounds and see faint movement.
Any suggestions please?
johnjan is offline   Reply With Quote
Old 08-14-2010, 09:13 AM   #2 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I would check the wire bundle that goes between the car frame and the door itself first. Odds are a wire has broken in there.
EDIT: It's protected by the black plastic tube thingy
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 08-14-2010, 01:27 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ +1. I'd bet money on it.
'07 Honda Ruckus Big Bore
Old 08-14-2010, 05:27 PM   #4 (permalink)
If a wire is broken, there should be no clicking sounds or slight movement, should there be?
Old 08-14-2010, 06:33 PM   #5 (permalink)
Freakin Scooters
I'd bet the wires are just partially broken and shorting out against other partially broken wires. Just open it up and look.
Old 08-16-2010, 03:36 PM   #6 (permalink)
Gameroom cash: $160515
View mdatrdcam's Photo Gallery
im having the same problem with my driver's door. was this ever resolved? did you find that it was just broken wires?
FULLY LOADED 01 V6 5-SPEED-INJEN INTAKE-TRD QUICKSHIFTER-FULL TRD SUSPENSION-TRD STRUT TOWER BAR
mdatrdcam is offline   Reply With Quote
Old 08-16-2010, 05:00 PM   #7 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
I have the same problem with my passenger door. I've been meaning to repair it for quite sometime, but I hardly have passengers. I know all of you say its a wire problem, but could the situation be remedied by replacing the door actuator?
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 08-16-2010, 05:24 PM   #8 (permalink)
TN's Mad Chemist
It should be easier to access the wire bundle on the front doors. That's what I would check as well. I just had an incident last week where my rear driver side window was going down but not up. As soon as I exposed the wires in that bundle I saw one was cut
Checking the wires would be the easier solution. Yes, it could be the actuator, but it's much easier to check the continuity in the wires with a Multimeter than replace an actuator
1997 Acura RL-Gone
Old 08-16-2010, 05:31 PM   #9 (permalink)
Chemist at Chevron
TBH, I don't think its the wires (but haven't gotten to it myself) cause when unlocking/locking, there is faint movement, and there is that click, which leads me to believe its something mechanical as opposed to something electrical. I'm curious. I think I will check it out sometime this week.
95 Camry LE I4 195k
Old 08-16-2010, 05:36 PM   #10 (permalink)
TN's Mad Chemist
This is how it would be set up in the door:
Actuator -> steel bar -> rotating "cuff" -> steel bar -> flimsy plastic connection -> red thingy that tells you if door is locked/unlocked
I would check that flimsly plastic piece. It might be broken. If you say you hear the actuator click, I think it's fine.
1997 Acura RL-Gone
Old 08-16-2010, 06:21 PM   #11 (permalink)
Chemist at Chevron
Good to know! Thanks!
95 Camry LE I4 195k
