94 L4 A/T Weird electrical issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-14-2010, 12:31 PM   #1 (permalink)
View Nebbuchanezzar's Photo Gallery
so, this car does not register being in D on the cluster, and pressing the brake pedal registers as being in R, also there are no Reverse lights when ACTUALLY in reverse...I figure some plug just got plugged in wrong and mixed these up, so I looked through my Haynes FSM, but didn't see anything in the back electrical diagrams about reverse lights at all...
Any ideas? lol...
Nebbuchanezzar is offline   Reply With Quote
Old 08-14-2010, 12:38 PM   #2 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
4th Generation
Any ideas? lol...
check the wire harness on transmission body, near the dipstick pipe
connect terminal 2 to 8 by paper clip or piece of wire, the reverse lights should become on
AliRazoR is offline   Reply With Quote
The Following User Says Thank You to AliRazoR For This Useful Post:
Nebbuchanezzar (08-14-2010)
Old 08-14-2010, 12:55 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
The D light bulb is probaby burned out. Have fun replacing it!
Chris Crash is offline   Reply With Quote
Old 08-14-2010, 04:52 PM   #4 (permalink)
Will check, but Chris, I understand that is one possibility, as well as reverse simply being out as well (I have a rear light out warning, but my top rear brake light is out too...) but that still does not explain why pressing on the brakes registers as going into reverse on the cluster...? and I kinda have a feeling/hope this is all one connected problem and something just got plugged up wrong or mixed up or something (hopefully!)
Old 08-14-2010, 05:21 PM   #5 (permalink)
Gameroom cash: $303755
Check the loom of wires inside the trunk by the driver's side trunk hinge. Open up the loom and chances are you will find frayed or broken wires in there. Fix what you find. Those wires fray and break from all the flexing they go through, as the trunk is constantly opened and closed over the years. If they just have the insulation frayed off a couple may be touching each other giving you the symptoms you are experiencing. If that's the case, a bit of electrical tape will fix your problem.
Mike
Old 08-16-2010, 01:46 PM   #6 (permalink)
well, I just looked real quickly at overall wires, and I need to replace a lot asap... I have exposed ground wires, as well as other wires that are splitting open, etc.
ATM, the car is still my gf's, and she doesn't want me to do too much, so I will have to wait until it is mine and I am replacing LOTS!
