as per the MAP sensor replacement. hold it off as last one, it's the least suspected.
BTW, there is FSM with testing methodology (voltmeter and vacuum pump required) for MAP. though I have to warn you that Toyota took a very hard way to do this - back probing the terminals at ECM with connectors plugged in. you would need special back probe pins for that.
I found an easier way to do the same test at the MAP electrical connector and when using a couple wires with alligator clips on them. no need to do this at the ECM which is located behind the glove box.
to test MAP check out SFI FSM, page 53:
http://www.camrystuff.com/manuals/Gen4/SFI.pdf
and then this thread for a shortcut (post#335 & 336):
http://www.toyotanation.com/forum/sh...23#post3214023
most likely MAP is good, it almost always is, because when it's bad the engine would be running like crap and even stalling at idle or had zero performance. MAP is a crucial sensor.
check all the vacuum hoses if they are not clogged (blow air through them) and check if they hold vacuum when connecting one end to the vacuum pump and plugging the other one securely.
If you decide to replace those hoses, let me know, don't use the SAE hoses from local parts stores, they will NOT be a tight fit. you will need metric hoses - I know that 3mm ID / 2mm wall silicone hose off ebay (Honk Kong, member ID zenaracing, cheap and sells short lengths too) for all EGR stuff is best bet.
but you SHOULD double-check if REALLY the VSV for EGR works good and most likely get the modulator replaced (it has filter in it). then do some testing on the EGR valve itself, it's all in the links I posted either per FSM I linked or per thread I posted. been there done that and ended up up replacing all three plus hoses to make it a complete EGR rebuilt and piece of mind for future. BTW, thanks to it I got dismissed the issue with intermittent poor acceleration on my 5s-fe and restored the MPG on car that was suffering from too much fuel consumption.
if you have obd2 scanner handy that can show you live output of oxygen/afr sensors and fuel trims then this might come in handy when testing.
good luck.
