Ha! I think they're worried about your user name!
What does that say about you? lol hey, just kidding and welcome!
So, your saying you had the cams out of the head?
If that answer is no, just place the cam belt drive gear back on the camshaft and align that gear to the mark on the heads cover. Align the crankshaft to the index on the timing cover at TDC and install the timing belt.
If the answer was yes, than your saying you have the cams out we need index them properly. Lets use the search and find a picture with photos and you should be OK. There are many so be patient and someone will chime in with input if its the later of the two because you have to align the spring loaded gear properly too!
This is bank2 on a V6, should look about like this. . .
