my exhaust's hanger is slipping out of the rubber holder. any ideas ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2010, 07:37 AM   #1 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
hey hows it going,
i just got my megan on and im having a little problem. the muffler hanger is slipping off the rubber thing. im afraid it'll actually slip off and my muffler will fall lol....
cause i had it on then i drove around for a few hours and then when i checked again, the rubber holder was on the very edge of the muffler hanger. i hope im making sense. does anyone have any ideas ?
thanks guys,
d
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 08-19-2010, 08:37 AM   #2 (permalink)
PortugalFocus's Avatar
Gameroom cash: $124395
View PortugalFocus's Photo Gallery
Try bending the end of the hanger downward, to make a kind of hook. That's probably the easiest cheapest way of making it work. Can you get a closeup of the hanger?
PortugalFocus is offline   Reply With Quote
Old 08-19-2010, 09:46 AM   #3 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Sounds like someone botched the install as they didn't position it correctly and then depending on which way the hanger faces, the pipe gets little bit longer as it heats up. Plus you have engine movement and all that stuff. . .
Take it back and have them lengthen or shorten the pipe to center the hanger or PF suggests, bend the hanger.
I see a coat hanger in your future!
73sport is offline   Reply With Quote
Old 08-19-2010, 10:04 AM   #4 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Another option is to get a depth/stop collar like this and add a washer. Hopefully there's enough of the shaft sticking out past the hanger to slip one of these on the hanger support. Cinch it down, and the hanger should stay put.
http://www.leevalley.com/en/wood/pag...80,42334,42335
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 08-19-2010, 10:50 AM   #5 (permalink)
V8'sRGone
73sport's Avatar
^^ the downside is that if its under strain and truly wishes to be pulled through the hanger then its going to strain the pipe, hangers ect and cause vibrations.
Obviously this under "no load" when being observed so who knows what it does when on the gas, breaking, doing donuts ect. . . .
Old 08-19-2010, 05:27 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
id there a barb or flare at the end of that metal hanger? my megan didnt have one and that woudl cause it to slip out. its a simple fox, just take it to a shop and ask them to either weld a ball bearing or something that will put some sort of lip on the end of the catback hanger.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-21-2010, 11:18 AM   #7 (permalink)
hey guys, thanks for the replies. i made a 15 hour drive then another 10 hour drive and it never slipped out but its like almost about to so im worried. it is actually a megan, the one bigbird have
i will take it either to a shop to have them bend the hanger or weld a little lip on the end.
thanks~~
^^^ List of my mods
