96 Camry Overheating - need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2010, 12:31 PM   #1 (permalink)
View whopkins87's Photo Gallery
My neighbor brought me this car and the top tank on the radiator was busted and spraying out coolant. I put in a new radiator today and I can't get it to stop overheating. The cooling fans are not coming on when the temp jumps up but I can jump the relay and get it to come on. When I drive it I have to put the heater on and when I come to a stop I have to put it in neutral and rev the engine up to 2000 rpm and that seems to drop temp a little. I don't hear any burping into the overflow bottle but it does burp out of the radiator if the cap is off. I am wondering if it may need a water pump now.
Any ideas.......
whopkins87 is offline   Reply With Quote
Old 08-22-2010, 12:42 AM   #2 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
Sounds like a failing water pump.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
The Following User Says Thank You to Nervous For This Useful Post:
whopkins87 (08-22-2010)
Old 08-22-2010, 04:12 AM   #3 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
4th Generation
AliRazoR is offline   Reply With Quote
The Following User Says Thank You to AliRazoR For This Useful Post:
Old 08-22-2010, 09:16 AM   #4 (permalink)
Nervous's Avatar
if you turn heat on MAX (when engine is hot) - does it blow hot air or just warm?
If ECT switch is bad but pump is good then when you turn heater on MAX it should cool down the engine not just "a little": it should bring the temp back to normal.
What is the engine, btw? The pic above is for 5sfe, as far as I can tell.
What is the mileage, is the pump original?
Old 08-22-2010, 11:51 AM   #5 (permalink)
Banned
4th Generation
yes, it is
Old 08-22-2010, 11:58 AM   #6 (permalink)
Banned
btw, did you test the fan relay?
try to change it with identical relay in your relay box?
