Would you do this???
Ok, I bought a 94 xle with 212000 miles on it for 1300 dollars. I am now finding some issues with it and don't know if I should put the money into it. Please give me your advise.
When I got it, the tranny slipped, but it was 2.5 quarts low. Now it is fine. There are two oil leaks, one will involve changing the timing belt, water pump, etc. About a 500 dollar fix. The other is the left front output shaft seal, which will involve changing the tranny fluid. Probably a couple hundred dollars. The tranny fluid is black. The strut mount is loose, causing a clunk. It seems to be using oil, but runs great! What would you guys do?
