Different types of Toyota Red Long Life Coolant? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2010, 12:00 PM   #1 (permalink)
View kjarrett's Photo Gallery
At the stealership getting parts for my radiator job, the parts guy said that some newer Yota's have a new "100k mile" formulation of coolant. I have a gallon extra I got and didn't use but plan to keep because I have the '97, my daughter has an '02 LE, and the wife has an '05 Rav4. The question is ... can the coolant I have be used in the Rav4 or does it need the newest stuff he's talking about? TIA!
'05 Rav4 L
'97 Camry LE
kjarrett is offline   Reply With Quote
Old 08-22-2010, 01:20 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
That new formulation is probably "Toyota Pink". It's pink, is super long life so the jug says, is premixed, and I think don't mix with Toyota Red. Open the rad cap and take a peek, or look at the coolant tank.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
The Following User Says Thank You to Buurin For This Useful Post:
kjarrett (08-22-2010)
Old 08-23-2010, 08:13 AM   #3 (permalink)
View djb2's Photo Gallery
Note that the pink only comes pre-mixed. That's common for a "lifetime" fluid. It doesn't need to changed during service, only the lost amount replaced. It should only be topped off with premix, never water, since you won't be able to restore the concentration to the proper level (actually a bit more than 50/50).
djb2 is offline   Reply With Quote
Old 08-27-2010, 02:01 AM   #4 (permalink)
View mr2crazed's Photo Gallery
I purchased a '94 recently and the radiator needs to be replaced soon. It currently has green coolant in it. Should I get the Toyota "red" when I install the new radiatior? If so, how to I get the remaining "green" out of the block (4cyl)?
'91 MR2 NA
'06 Tacoma Prerunner DC
'94 Camry LE (sons car, GONE as of 3-21-11)
'98 Mazda MPV (wifes car)
mr2crazed is offline   Reply With Quote
Old 08-27-2010, 02:07 AM   #5 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
4th Generation
DIY:1993 Camry 5SFE A/T Radiator Replacement
Gen 3 I4 Radiator Change/ Thermostat Change
AliRazoR is offline   Reply With Quote
Old 08-27-2010, 02:29 AM   #6 (permalink)
So is it worth it for me to completely change out the "green" and go "red"?
'91 MR2 NA
Old 08-27-2010, 02:49 AM   #7 (permalink)
Banned
4th Generation
yes,i use the red one.
when i opened the lower cover of radiator after 80000km, NO RUST,NO clodge
Old 08-27-2010, 06:44 AM   #8 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Pretty much everything '05 and after is going to Super Long Life. For those who are doing a complete radiator change and flush, technically you can put in the SLL, but remember, since its premixed, you'll need more coolant, but IMO its overkill.
I have an '04 Camry that takes Long Life, an '05 Camry would take SLL, and even though I could and have access to SLL that most don't, I'd stick with the Long Life and not go out of my way to put in SLL.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
