92 Camry rear bearing vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2010, 11:29 AM   #1 (permalink)
View azcat90's Photo Gallery
3rd Generation 92 Camry rear bearing vibration
Is it normal for my 92 Camry LE V6 rear wheel bearings to vibrate only occasionally when they go bad?
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
azcat90 is offline   Reply With Quote
Old 08-23-2010, 11:45 AM   #2 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
4th Generation
is your tire balance?
AliRazoR is offline   Reply With Quote
The Following User Says Thank You to AliRazoR For This Useful Post:
azcat90 (08-23-2010)
Old 08-23-2010, 12:01 PM   #3 (permalink)
Old tires
Tires are old so it has been more than 2 years since it was checked. Are you saying that if it was the bearing it would be a constant vibration not just an occasional one that only occurs above 60 mph?
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 08-23-2010, 12:08 PM   #4 (permalink)
Banned
release the hand brake
jack up the car(first put something in front of front wheel )
remove the wheel
remove DRUM
turn the hub by your hand
listen for any abnormal noise
if you hear something might be bad BEARING
Old 08-23-2010, 12:12 PM   #5 (permalink)
Banned
4th Generation
i think so.if you check it is better.
the bearing is expensive
Old 08-23-2010, 12:27 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
bearings will shift pitch at speed. At a speed of 35 to 45 windows up, air off, radio off, listen as you drive straight down a smooth paved road. Now take a slow left, turn right, turn left shifting the cars weight from side to side.
Bad bearings will make noise as they become loaded. The right rear would likely make noise when you turn left and weight is transferred to the rightside.
Beyond that, block the car, jack the rear, have a helper spin the wheel (brake off), place stethoscope to the hub area. If it sounds like gravel, its bad or going bad. It more likely you hear the wisp of the brakes dragging. Try not to confuse the two.
Listen to the engines alternator for perspective on a bearing. It'll be loud with a stick to you ear.
hint: broom handles cut down, long screw drivers, and stethoscope are handy for listening to noises. Use a paper towel tube to listen to vacuum leaks, coil sparks jumping, ect. . .
How many miles on the 92?
73sport is offline   Reply With Quote
The Following User Says Thank You to 73sport For This Useful Post:
Old 08-23-2010, 12:31 PM   #7 (permalink)
V8'sRGone
73sport's Avatar
Miles?
Does it have a trailer hitch?
Has it ever been under water!
OR - severe use, super hot, super cold, real dusty are WET?
Old 08-23-2010, 02:52 PM   #8 (permalink)
73Sport/AliRaZOR: Thanks for the tips.
I'm prettry sure I have a bad left rear bearing - it will start grinding at 65 mph but not every time I get up to that speed. It eventually smooths out after about 2 minutes of driving but it is getting more frequent.
It has 173K miles. Not flooded - western PA climate - garage kept most of the time -some severe use - no hitch. Did you have to replace the rear bearings on your 95? If so do you remember at what mileage?
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 08-23-2010, 03:13 PM   #9 (permalink)
V8'sRGone
73sport's Avatar
Not yet. 95 has 226,xxx miles on it. Since 2005 its been pushed into the corners hard since 142,000 when I took ownership and no problems yet.
Can you please try to describe your perception of vibration vs grinding? I'm just trying to separate tire/wheel vibration from bearing noise.
Also, if you pulled the brake drum off, you might be able to see where grease came out of the bearing and more importantly feel the bearing by turning it.
I have had a wb explode and lock up a wheel. Not a pleasant experience but I would say is very rare. Most just get noisy and you find yourself having to pump the brake pedal as the added free-play at the hub/rotor/drum pushes the brake pistons in further as the braking surface no longer runs true.
Synapses of bearing failure:
1) seals let the grease out or the hardening if either the balls or the inner/outer race fail
2) w/out grease or with the induction of particles in the bearing it wears to an audible point making noise.
3) as the wear and noise continue, the bearing may develop some free play that can be felt/measured.
4) the surface hardening breaks away either A) creates lots of tiny particle or b) larger parts of material depart sometimes destroying the bearing cage and then the bearing has catastrophic failure.
edit: 1a, would be time and heat harden the seals that let the grease out, that let the dirt and/or water in ect then failure takes on 1, 2, 3, 4 . . .
azcat90 (08-24-2010)
Old 08-23-2010, 03:31 PM   #10 (permalink)
View GOT BOOST's Photo Gallery
Here is a much easier test...
1) Jack and secure the vehicle with jack stands or axle stands.
2) Try to rotate the tire from side to side and up and down. Ie) Is there play when you try to move the tire in and out from when your hands are placed in the 9 and 3 position and the 12 and 6 position.
4) Check your rear lateral arms for play in the bushings. Just because your tire moves, it does not mean it is the bearing. Sometimes the movement can come from a worn bushin in the lateral arm.
The bearings in question you can get from a junk yard. It is easier to pull the hub and replace it, rather than try to press a new bearing into a hub with a worn bearing. Sometimes the bearing will have taking the bearing race out of round causing the new bearing to not fit correctly.
Click here for a cross check on your part number. http://www.car-part.com/
From there you can check your local wreckers or a pick and pull online inventory to see what they have in stock.
GOT BOOST is offline   Reply With Quote
The Following User Says Thank You to GOT BOOST For This Useful Post:
Old 08-24-2010, 10:02 AM   #11 (permalink)
3rd Generation Possible worn bearing
I'm driving along and all of a sudden it feels like I lost the tread and it sounds like an airplane engine (propeller). After about 2 minutes it gradually dissapates.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
Old 08-24-2010, 10:59 AM   #12 (permalink)
V8'sRGone
73sport's Avatar
Exclamation
YIKES! I'd roll into your local tire shop, have them hoist it. Give the suspect wheel a spin to confirm and head straight to the parts counter/bone yard and grab a bearing.
THAT doesn't sound like something that goes unnoticed and could damage other parts!
Park it until repairs are made.
Video/audio to add to the trouble shooting threads. . . ???????
Old 08-24-2010, 01:27 PM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
azcat90 - if you're interested in DIY'ing the rear bearing replacement, I posted one a while back; it's a pretty easy job...
Rear wheel bearing R & R - How to and why
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
Old 08-24-2010, 05:33 PM   #14 (permalink)
V8'sRGone
73sport's Avatar
Nice clean pictures too!
So the fall out started at 250,000 miles and all four wheel bearings died by 275,000 miles? I'm just guessing. . . You still have this car and how many miles on it now?
Old 08-24-2010, 11:55 PM   #15 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Thanks 73sport!
The vibrating actually started sometime before 200k; not sure when. It wasn't too bad at first, I just put up with it for a very long time. At first, turning the rotors would make it go away for a little while; like 10k miles or so. But it slowly got worse and worse. At one point I put a new set of tires on it and it improved a bunch, but still there. At that point, I suspected the wheel bearings were running a bit wobbly and screwing up the rotors, tire balance, and even tire roundness. That suspicion was what finally convinced me to try replacing wheel bearings, and it was correct.
In hindsight, one of the four (the drivers-side rear) wasn't all that bad. But yeah, they were all contributing to the vibration to some degree.
305k on it now. The cheapy $100 eBay wheel bearing is still holding up! (crosses fingers & knocks on wood)
Tags
bearing, camry, hub, vibrate, wheel
