melted my harness and.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2010, 12:01 PM   #1 (permalink)
View itiswhatitisa5's Photo Gallery
Car; 1996 2.2l 5sfe a/t camry. 170k
Cause; put my egr tubbing on backwards and melted my wiring harness.
Effect; car will turn over, get fuel, but no spark.
What I did; Upon melting the harness I then inspected and noticed I only melted the insulation on one wire ( it was solid white with a thin red stripe down it) I taped everything up and reinstalled the egr correctly. I tried to get a diagnosis code, no el worko. I checked the fuses in the engine bay and behind the driver side panel. Nothing. I dont think im getting power to the ecm, i checked E1 and a good ground and got nothing.
I know for sure im getting fuel, the fuel line after the filter is hard and i can hear the pump. Just no spark whats so ever.
What should i do?
any suggestions are greatly appreciated.
itiswhatitisa5 is offline   Reply With Quote
Old 08-24-2010, 12:54 PM   #2 (permalink)
FIXED. was the AM2 fuse
Old 08-24-2010, 06:53 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Old 08-26-2010, 09:22 AM   #4 (permalink)
everything seems fine now sorta.. fixed a small egr leak ( helps if uour torque things down right). but now, the 5sfe wont rev up past 3500rpm's. it kind of cuts out. falls and drops..
