Is there any truth to the Aussie A541E,s having a different final drive ratio compared to the others? Its not much, but if rebuilding it might be worth checking into. . .
Example at 4000RPM with 225 50R17 in 1st gear its 27mph vs 30.5mph.
(USA 1997-2004) gear ratios 1st 2.81,2nd 1.549,3rd 1.00,4th 0.735,
final drive 3.625
(Aust 2000-2004) gear ratios 1st 2.81,2nd 1.549,3rd 1.00,4th 0.735,
final drive 3.933
Then again, some literature says its the other way!
Just looking at the trans a little closer these days. . .
This compares the 540 to 541, changes when bolted to the 1MZ.
http://www.mr2.com/files/mr2/techinf...ta/94a541e.pdf
Page 8 (scanned pg 73) explains squat and how shifting from N to D the trans initially engages 2nd gear to reduce vehicle squat. I always wondered how they did that!
Regards,
73
