P0303 error on 2000 camry 4-cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2010, 10:22 PM   #1 (permalink)
View JerryGiese's Photo Gallery
Hey guys. All of the sudden today, my engine started running rough like it is missing and the check engine light came on. I took it to autozone and got a P0303 error (misfire on cylinder 3). I replaced the spark plug on 3 as well as the ignition coil. I check the compression and got 165 psi. I swapped fuel injectors with cylinder 2. But I'm still getting the P0303 (misfire on cylinder 3) error. Any ideas?
JerryGiese is offline   Reply With Quote
Old 08-27-2010, 12:46 AM   #2 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
i am not sure but i think when you solve the problem, you have to reset the ECU
AliRazoR is offline   Reply With Quote
Old 08-29-2010, 08:46 PM   #3 (permalink)
View ls2ws6's Photo Gallery
bump, I have the same problem with my 2000 camry 2.2 , PO303.
New plugs, fuel injectors were removed and tested good, I bought plug wires and havent changed them yet
ls2ws6 is offline   Reply With Quote
Old 08-29-2010, 09:14 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check the resistance of plug wire from end to end on cyl#3, it should read no more than 25Kohm IIRC. you may need a set of new wires.
if so get NGK TE58, they are cheap like $28 on amazon shipped free or $40 at local Advance Auto Parts.
165psi seem like a little low compression on that cylinder IMO, what are the rest at ? because what matters is how they look compared to each other while measured on engine at same (or similar) temperature and with same gauge.
Old 09-15-2010, 01:58 PM   #5 (permalink)
** Problem solved. It was the plug wire(s). Funny how I over analyzed the whole things, first by pulling and having the injectors tested, and then having the coils tested.
Either way happy to say it was just a 40 dollar set of plug wires to clear up my misfire
Old 09-15-2010, 05:27 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
glad to see it's fixed
did you get NGK wire set? it's a very good brand, can't go wrong with those
Old 09-29-2010, 03:13 PM   #7 (permalink)
No they were duralast from autozone (w/ a lifetime warranty)
I would have gone for the NGK set had I ordered them online though
