coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2010, 02:27 AM   #1 (permalink)
Nite Owlz
View Kdub26's Photo Gallery
coolant
ive always used the factory red toyota coolant to top off my overflow. im doin a motor swap here in the next few weeks. called the local toyota and paying $25 before tax for a jug of coolant just seems kinda high. just wondering if i can go with prestone or peak 50/50 coolant instead of factory red?
Kdub26 is offline   Reply With Quote
Old 08-29-2010, 08:42 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Peak Global Lifetime is whats best. Its this sorta pee colored yellow, They don't sell it in walmart and it took me a couple trips to a couple stores to find it.
Its like 8$ a gallon.
carsrus is offline   Reply With Quote
Old 08-29-2010, 02:45 PM   #3 (permalink)
Nite Owlz
sounds good. i figured it would be easier to get an aftermarket coolant since its more available than going to the dealership. i just didnt know if it was one of those weird things that i HAVE to use the factory red coolant. but then again, its a 15yr old car so it wouldnt void any warranty or anything.
Old 08-29-2010, 02:57 PM   #4 (permalink)
Gameroom cash: $115300
View TCam01's Photo Gallery
If i were you i wouldn't cheap out on something so important
Yota Camry 2001 5S-FE 105,430 Miles+
TCam01 is offline   Reply With Quote
Old 08-29-2010, 05:45 PM   #5 (permalink)
View Nebbuchanezzar's Photo Gallery
Well, I would say use the red...I mean...the MAIN difference is pretty much rust control...but also, think about it this way...even if it is $25, how often are you going to change your radiator fluid? probably once per year as recommended, right? So that's $25/year...not so much, although at the same time, IDK that the red is a HUGE jump...but I would go for it for sure...just my 2 cents
Nebbuchanezzar is offline   Reply With Quote
Old 08-29-2010, 05:59 PM   #6 (permalink)
10gxiong's Avatar
View 10gxiong's Photo Gallery
I would go with the Toyota coolant just because its factory recommended, but on the other hand... it seems kind of similar to a question about oil, transmission oil, or brake fluid, the list goes on... I use Toyota's brand for some stuff, and I don't for others... and the car's perfectly fine since I maintain it at consistent intervals.
1998 Toyota Camry LE - Super White
2006 Scion tC - Black Cherry Pearl
10gxiong is offline   Reply With Quote
Old 08-29-2010, 06:21 PM   #7 (permalink)
Once per year to flush your rad? More like every 3-4 unless you drive like 40k per year.
Old 08-29-2010, 07:12 PM   #8 (permalink)
Well, I drive 75 miles one way for work...that comes out to about 39k miles for work alone...not mentioning around the town, etc. and according to Haynes FSM, the recommended interval is 30k or 24mo...
That IS another advantage to Red tho, is it does have a longer life, does it not?
Old 08-29-2010, 07:34 PM   #9 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
I like the fact that Toyota gives generic specs for most fluids (AT, PS, brake)...except coolant. So, I follow that one exception and buy the OE red. One jug plus a sub $1 gal of distilled water and you're good for 24k/24 months. The selection of coolant by the manufacturer is based on the various metals and seal compounds in contact with the coolant. For less than $20 difference, I'll go with the stuff that makes it less likely I'll need to do an unscheduled water pump swap or replace a rotted heater core ever.
Interesting to see how much cynicism there is regarding Toyota recommending the one special fluid the car was designed to use, but not toward Peak/Prestone et. al. for claiming their products are "universal", or nearly so.
Virtually all coolants are still ethylene glycol based to provide the anti-freeze capability. The "low toxicity" varieties are an exception. But the use of OAT, borate and silicate additives, etc., for anti-corrosion and other characteristics, make for real differences. To me, it's worth a buck a month to get the right stuff.
TedL is offline   Reply With Quote
