1995 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2010, 10:05 AM   #1 (permalink)
View Taylor63's Photo Gallery
1995 camry
I Have a 95 4cyl Camry that ran HOT, I 've had the head off and surfaced. Got it running, But It's now hard to start when cold. the when it idles it has a miss I cant put my finger on. but if u go above idle it seems to run fine. Any Ideas? Could it be the TPS or the idle air control?
Taylor63 is offline   Reply With Quote
Old 08-30-2010, 10:17 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Could be something in the emissions, but i'm not 100% sure at all. Have you tried cleaning all the emissions junk out? Maybe with some seafoam? There's plenty of DIYs in the sticky and info if you search.
'07 Honda Ruckus Big Bore
Old 08-30-2010, 10:40 AM   #3 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
If you took the heads off maybe your timing is advanced.
LittleWhiteBubble is offline   Reply With Quote
Old 08-30-2010, 11:47 AM   #4 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
97 LE 4 cyl, should I keep? What would you do?
Car doesn't want to idle....fed up! Think its good bye : (
AliRazoR is offline   Reply With Quote
Old 08-30-2010, 12:37 PM   #5 (permalink)
Maybe, but I've checked and rechecked all cam timing and crank timing marks., Can anyone tell me if it has a cold start curcuit?
Old 08-30-2010, 12:59 PM   #6 (permalink)
92 Camry 5S-FE
When you put the distributor back in did you line it up as well? If you only marked the timing belt gears the distributor could still be off
