You need to pull the hose off and inspect it. I would probably go ahead and replace the hose if yer putting a clamp on it to keep it in place. What does the other end look like?
Did you make sure the EGR tube is clear and not carbon fouled closed?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
