Help with leak on 92 xle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2010, 07:40 AM   #1 (permalink)
cmvondran's Avatar
View cmvondran's Photo Gallery
Ok guys I need your help with a fluid leak. Two months ago I replaced the valve cover gaskets thinking they were the problem but from under the car there are no leaks coming from the seal.
I have burning fluid coming off the back motor where O2 sensor is, which is causing the motor to smoke bad.
I thought it was a my power steering fluid keeps going low as well. I pull the tire and the area around the pump are really wet.
any suggestions? if the pump is bad how is the fluid dripping on the exhaust manafold in the rear?
does any one have a pic of the rear of the v6 motors?
cmvondran is offline   Reply With Quote
Old 08-31-2010, 07:57 AM   #2 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
blue smoke comes out of exhaust pipe?
AliRazoR is offline   Reply With Quote
Old 08-31-2010, 08:56 AM   #3 (permalink)
Nervous's Avatar
Gameroom cash: $275064
View Nervous's Photo Gallery
There is nothing to leak there but valve cover gasket. Check if it is installed correctly. Clean up everything there and check for traces of new oil after a ride.
Camry Sedan 1996 LE V6 1MZ - 170 Kmiles
FOR SALE, Sedan/Wagon parts
Nervous is offline   Reply With Quote
Old 09-01-2010, 03:03 PM   #4 (permalink)
cmvondran's Avatar
I did not say anything about blue smoke.....
I think I found it. the drivers side boot is leaking and oil is getting on the half shaft and getting thrown every where.
