95 camry 4-cyl hard to start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2010, 12:39 PM   #1 (permalink)
View Taylor63's Photo Gallery
It's me again, 95 camry got timing on the money but car is very hard to start when cold any thoughts? I've checked the distributor coil, TPS, IAC etc.all checks good by the book. I have noticed that it still to start a little betterif I jump the fuel pump and try to start.
Taylor63 is offline   Reply With Quote
Old 08-31-2010, 01:55 PM   #2 (permalink)
View toovira's Photo Gallery
Have you checked the fuel line pressure after the fuel regulator?
toovira is offline   Reply With Quote
The Following User Says Thank You to toovira For This Useful Post:
Taylor63 (08-31-2010)
Old 08-31-2010, 02:12 PM   #3 (permalink)
No not sure where to trap into the system at?
Old 09-01-2010, 01:34 PM   #4 (permalink)
Gameroom cash: $303755
If the car turns over at normal speed when cold and otherwise runs well when warm, I would also check the engine coolant temperature sensor for being out of range. It may be telling the car's computer the engine is warm, when it is cold. To do this you will need a digital volt/ohmeter and the specs from any manual. If you do not have manual you can download one for free at the top of the Camry forum over at AutomotiveForums.com. Download the generation 3 manual. Here's the link:
http://www.**********s.com/camry/
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
Taylor63 (09-01-2010)
Old 09-02-2010, 10:32 AM   #5 (permalink)
JUst checked pressures, 45psi with pump running. after 10-15min just sitting pressure still at 40psi.
Still not running/ firing..
Old 09-02-2010, 10:36 AM   #6 (permalink)
Thanks, Mike this helps. By the way do you know of any sites for GM manuals? Got a friend with GM troubles..
Old 09-02-2010, 11:28 AM   #7 (permalink)
Taylor63,
Sorry, I can't help with the GM manuals.
Mike
Old 09-02-2010, 06:11 PM   #8 (permalink)
Originally Posted by Mike Gerber View Post
Taylor63,
Mike
Mike, My car will not start, cold or hot IF it does happen to start it seems to run fine and then it will just cut off / stop running. And it may try to start it hits but will not run. I check the fire when this happens and it has fire, and i can smell fuel. Could it be losing fire? The distributor coil checks by the book but it has a big crack in the resin. Any thoughts on this?
Old 09-03-2010, 12:28 PM   #9 (permalink)
3rd Generation It's running yea!!!
OK ,Guys I've Found the problem..Thank GOD. It had fire but not enought to fire under pressure I Replaced the Distributor Coil and SHE Fired right up and Drove Fine. Wish Me Luck, I NEED it. THANKS to ALL for the Input and Help...Richard Taylor..
Old 09-03-2010, 03:27 PM   #10 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Mr.Taylor,I deleted your other thread and merged it to this one. Try not to have two threads going on the same subject.
Congratulations on finding the solution to you problem.
to ToyotaNation
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
The Following User Says Thank You to eyeball96 For This Useful Post:
Taylor63 (09-04-2010)
