98 Camry leaks behind Distributor?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2010, 02:39 PM   #1 (permalink)
View Recycleableone's Photo Gallery
OK I know its not actually a distributor as such but my oil leak does appear to be dripping down from the mounting brackets for the ignition...
The motor has to run for at least 15 minutes for this leak to show up but when it does its a steady drip....under heavy acceleration it blows oil all over the engine/exhaust....
Any ideas as to how to fixthis? I had a mechanic try by changing the vc gasket........no change .....I changed the timing belt, crank, oil pump,cam seals....no change........\
So where do I go next??
Recycleableone is offline   Reply With Quote
Old 09-01-2010, 03:01 PM   #2 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
On the back of the head there is a cam plug(90339-36001) about where a distributor would go. It can and does leak from there. It is fairly inexpensive if you replace it, especailly if you are going to do a valve cover gasket, in a jam you could put some sealant on it and it will take care of it. My advice, for the money, if you are doing the V/C gasket, just splurge and replace it. It is $2.84 MSRP, so it isn't a high dollar item.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 09-01-2010, 04:04 PM   #3 (permalink)
Thanks....
SO does this seal go in from under the valve cover or the outside??
I do appreciate the help!
Old 09-01-2010, 08:52 PM   #4 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Another thread about the same problem...with a diagram!
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 09-02-2010, 06:55 AM   #5 (permalink)
the plug goes on the outside
678-854-9601
