Parts & Camry Built in Japan
I ordered a windshield reservoir for my Camry from an online source. The identified the proper part via the VIN. The part identifies the car correctly, i.e. CMRY/91-93(w/ ABS). The part is LT-TY2064ABSA / TO1288102. However, this part is slightly different than the original. For instance it does not have the third screw mount to fix the hose from the engine coolant. Also the hose that connects to the motor has a slightly different size that would result in a leak.
I can get the above to work but it begs the question why the part has some variation. Supposedly this 93 Camry was built in Japan. Could that be the reason? But if so wouldn't the VIN still identify it properly?
