Mildew smell in A/C? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2010, 11:44 AM   #1 (permalink)
View Bobelvago's Photo Gallery
I own a 1997 Camry and I was just wondering.
Yesterday, I turned on my car, and I smelled mildew, I said no worries, might just be the laundry I had in my car.
But then I smelled it again later, no laundry this time, and noticed it's coming from the A/C.
I've been searching for solutions, people say it's a cabin filter but others say it's not, some people say the true solution is to leave your windows open, some say to buy a cleaner kit. Some say put the heat on max to burn it off.
What do I buy? or what do I do?
Bobelvago is offline   Reply With Quote
Old 09-05-2010, 11:49 AM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
I use Ozium. It's a little 6-8 oz can you buy from Walmart in the car air freshener section. It's a sanitizer, and I'll spray a burst in every vent, and then into the cabin air intake as well.
Seems to work wonders for me.
Chris Crash is online now   Reply With Quote
Old 09-05-2010, 11:51 AM   #3 (permalink)
But won't a spray just cover up the smell? How long does your method last before you need to spray it again?
How much is the can (autozone puts it at $2.99 for a really small can...do they make big ones)? And where is the cabin air intake filter thingy to spray into?
I might as well try this unless there is a permanent solution.
Old 09-05-2010, 12:21 PM   #4 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
these cars do not have AC filter
AliRazoR is offline   Reply With Quote
Old 09-05-2010, 12:22 PM   #5 (permalink)
Banned
you can also remove the air blower and clean it
Old 09-05-2010, 12:26 PM   #6 (permalink)
Air blower? How do I get to it? I think just spraying into it would be easier but uhh ok.
Old 09-05-2010, 12:28 PM   #7 (permalink)
Banned
remove the glove box,it is there
Old 09-05-2010, 12:37 PM   #8 (permalink)
I think spraying it is easier than removing a glove box lol, although it's simple, you have to be careful due to the air bag behind it, right? So eh, spraying may only work for a month or two but it's cheap and easy to just spray in the vents lol.
Old 09-05-2010, 12:42 PM   #9 (permalink)
Banned
no,it is not so difficult.check this out:
http://www.honda-tech.com/showthread.php?t=457308
Old 09-05-2010, 12:43 PM   #10 (permalink)
Banned
4th Generation
it has nothing to do with air bag
Old 09-05-2010, 12:49 PM   #11 (permalink)
Oh so taking off the glove box doesn't affect it? I guess it's just newer cars then.
So reading that thread, I clean the blower which is right under the glove box after removing some bolts. Might as well try it.
Old 09-05-2010, 01:26 PM   #12 (permalink)
The spray is a sanitizer, so it gets rid of the smell. Doesn't cover it up.
I've only had to spray it once in each car, until a different smell arises from a different problem haha.
Also, you can use this stuff in your house vents, anywhere that smells really.. we have a few cans here.
Old 09-05-2010, 01:32 PM   #13 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Spray should be fine to start. Easier if you adjust air control to recirculation and spray though intake under dash with blower on high. You might have crude in drain pan or partially blocked drain, but I'd try spray first.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 09-05-2010, 08:48 PM   #14 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
When my original evaporater exploded (literally, it made a pop and the vents had white gas spewing out), it smelt like something had just crawled in there and died.
I have changed every part of the A/C except condensor and hoses...but the smell seems to reappear from time to time especially after humid days and not using it.
Pep boys sells something called 'vent-fresh' and you spray it in inside and outside vents...its not a coverup but actually kills the molds in the vents. Reapply every 6 months or so. $10.
And make sure to turn the A/C on often otherwise the evaporator gets acid at the bottom and stinks up everything. I think I need to become a friggin A/C tech after all this sh!t LOL
96ToyoCam164K is offline   Reply With Quote
