oil filter cup wrench (for 3/8'' drive) - LOVE it! :D
hey guys,
just wanted to share how much I love this Imperial Tools cup wrench for the oil filter. it works perfectly fine on my 5S-FE oil filters (used 3 times so far):
This one is IF-6567C (65/67mm or B cup size per manufacturer ... whatever they mean hehe).
I bought it in Walmart's at like $4. it's made of some composite plastic and fiberglass and has a metal insert for ratchet extension (3/8'' drive). I LOVE IT!
Imperial IF-6567C
e.g. for Purolator PureOne PL14476/PL14477
e.g. for FRAM TG4967 (not that i recommend those filters, but it's easiest to check in store if it fits if you know FRAM oil filter part number hehe)
It also fits Toyota OEM and Denso filter for 5s-fe perfectly fine, I would guess it fits them ALL (for 5s-fe application of course)!
so far I was using my own precious hands to remove my 5s-fe oil filters, because I found ZERO working jaw grip pliers or strap wrenches that would fit this small sized filter (they were either spinning around it or crushing it spilling oil out).
Now, i'm looking for the Imperial part number of same type cup wrench, but for my 1mz-fe oil filter ... anybody using it ? anybody knows which one ?
If you find one for the 1MZ, let me know, I'm looking for one. Doing that change last weekend sucked. Burned my hands
EDIT: I guess the easy way is the way I found the 5SFE cup...go to advance and grab a filter for the 1MZ then try it out on all the cups till one fits!
Yeah, those things are the shiznit! I've got 3 of 'em in diff sizes. I've got one that fits the filter for my Camry and the Avy (same filter) but it's a different brand, and metal.
Get one of these, it adjusts to fit most all filters. Comes from Sears.
geez, man, this looks serious ... have you seen the Saw ?
Originally Posted by Chris Crash
I LOVE that thing! It's amazing.
hehe, yeah they are amazing
i tried that for 5s-fe in AAP store and NONE of them fit haha ... wondering what luck i get with 1mz-fe filter over there.
but then i just need one more, don't want to have total of 5 (with 1 double) when i will be using just 2 of them
... trying to minimize amount of garbage in my trunk hehe...
Chris, go to Wal-Mart, they have one for the 1MZ You'll need to use a 3 inch extention along with it. I love it! Also, but a set of cotton gloves of sort, I find that helps!
Thing about the plastic ones is with time, the inner cup wears out a bit. Took 3.5 years of oil changes on 3 cars for mine to finally wear out, so they do last awhile But yes fenixus, that tool is awesome!
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
dang, just checked my closest Walmart and yes they sell it (7476C for 1mz-fe) ... though they were sold out on this one LOL
all they had was 2 pieces of 6467C for 5s-fe and 1 piece of something huge (9497C or something).
Then i checked out their oil shelves as I was looking for Royal Purple 5w-30 supply ... and they had only 3qts
later in the evening or tomorrow evening I will go to the other Walmart and see if they have it. i hope they are also better stocked with oils
funny, my local Autozone doesn't carry RP oil at all.
yeah, but AAP oils are expensive like hell (same about AZ) unless you get it on promo DIY oil change deal together with filter. I no longer buy oils in AZ since they always give some crappy filters like FRAM with everything even Valvoline ... unless they sell M1 FS with M1 filter then i can take it from them.
AAP is not bad with oil promo deals (I like their Purolator Pureone filters at $2 extra over the deal price).
... but since i've got my own stock of OEM filters (case of 10) all i need is a good (e.g. Walmart's) price on Royal Purple
And I don't need gloves. I'm a badass.
LMAO good one
tested it on Fram TG3614 (for 1mz-fe) in store and it fits perfectly well and tight
they had plenty of 1mz-fe filter cup wrenches in the other Walmart at $3.97
... though the other one did not stock Royal Purple at all (not even an empty shelf) hehe ... i might wait a couple days or week to pass and re-visit the first Walmart to check on RP stock
shit ! the joy was short
7476C (74/76mm & 15 flute) does NOT fit the original OEM toyota filter 90915-YZZD1 for 1mz-fe ... so it's rather just for WIX (not 100% sure but there is listing of a bunch of NAPA filters that fit this one), FRAM (e.g. TG3614 fits), Motorcraft (e.g. FL400 fits), etc ...
the problem is that the Original Toyota/OEM (and Denso likely too) filter has only 14 flutes with 74mm diameter while this socket has correct 74mm diameter it has 15 flutes so they don't fit together
i guess next step is to get 4 cup sockets from HFT at $5.99 and see if any of those fit ...
because as far as i know Walmart doesn't carry metal Imperial cup wrenches and the only one of them that would fit OEM 1mz-fe filter would be IF-7414 (74mm & 14 flute design)...
