P1135 Code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2010, 10:21 AM   #1 (permalink)
View khart05's Photo Gallery
Unhappy P1135 Code
I have a 2001 Toyota Camry V6 engine. My check engine light came on while i was driving on a side street. The codes that came up were P1135 and i think P0135. It came up as a air/fuel ratio sensor. I replace the sensor closest to front of the car (the one between my engine and radiator) but the light keeps coming back on after i reset it. I even tried unplugging my battery. Any help would be appreciated!
khart05 is offline   Reply With Quote
Old 09-07-2010, 10:26 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i believe P1135 relates to AFR heater on rear bank sensor (by firewall), not by the front of car.
P0135 is Heated Oxygen Sensor Circuit - Bank 1 Sensor 1.
Old 09-07-2010, 11:07 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Bank 1 Sensor 1 (b1s1) THIS ONE
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 09-07-2010, 06:00 PM   #4 (permalink)
glen-
i replaced the one in front of the radiator...should i put the old one back in and put the new one in that spot?
Old 09-07-2010, 06:08 PM   #5 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Originally Posted by khart05 View Post
glen-
Personally, I'd replace them in pairs because you'll soon get a P1155 or even a P1153 for the one on the front bank (closest to the radiator).
Denso 234-9021 (2001+ only) at Amazon is around $106.
Amazon Amazon
OE spec, but not an OE/stealership price. Not sure if you already knew that.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 09-08-2010, 01:46 PM   #6 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
If they're interchangeable, I'd opt to see that that error goes away by swapping in the new one. If it fixes it, go ahead and budget for the other. . .
just my poor 2 cents...
73sport is offline   Reply With Quote
