97 Camry Washer fluid Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2010, 07:45 PM   #1 (permalink)
View shady1070's Photo Gallery
My light will not go off for my wash fluid in my 97 camry 2.2l. I went underneath the car and wiggled the little connector and it did not help. Is there a sensor or something that could be bad. What would you check first? What is the part number to the sensor. If its cheap, I might just order it.
shady1070 is offline   Reply With Quote
Old 09-08-2010, 08:56 PM   #2 (permalink)
View 97ToyCar's Photo Gallery
There are different part numbers, because there were different manufacturers, so you will need to look at your old parts to match them. The pricing might be a bit old, but it should be close. The first two listings are for the TMMK Tennesee built cars. The second set is the TMC Tsutsumi, Japan built Camrys.
85397SWITCH ASSY,LEVEL WARNING85397‑AA010MCV20, SXV20..NAP; ITTA-ESNA1$59.4685397‑AA020MCV20, SXV20..NAP; NIPPON DENSO1
85397SWITCH ASSY,LEVEL WARNING85397‑33230MCV20, SXV20..JPP1$59.46
97ToyCar is offline   Reply With Quote
Old 09-08-2010, 09:13 PM   #3 (permalink)
IS there a way to just disable the light?
Old 09-08-2010, 09:32 PM   #4 (permalink)
If you disconnect the sensor, that should snuff out the light. If not, you'll have to pull the cluster and remove the bulb itself.
