99 Camry LE V6 starting trouble. PLEASE help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2010, 03:30 PM   #1 (permalink)
View rtmaran's Photo Gallery
USA 99 Camry LE V6 starting trouble. PLEASE help.
Hello all,
I have a '99 Camry with 153K miles on it and current on all maintenance. The car is running fine expect for a starting trouble which is happening more frequently. The batter is brand new.
Symptoms:
Cold starts are always good. Or starts after couple of hours of long drives are good.
If I drive for an hour and then stop and then try to start again it takes 3 - 5 cranks. The engine cranks up and revs upto 1000 RPM and dies within 2-3 seconds.
I have to turn off the radio, buckle up (to avoid the beeps), apply hand brake (to shut-off headlights) then crank up then it holds on. Not really sure if all these steps really helps or I am just following a routine blindly :-)
Everything else is absolutely fine with the vehicle. Only this issue is bothering me and I do not want to get stranded.
I talked to my mechanic about this problem and he thinks that Gas is the problem. But I do not believe so, I use 93 Octane.
Please help..
rtmaran is offline   Reply With Quote
Old 09-12-2010, 01:36 AM   #2 (permalink)
View eevee11's Photo Gallery
is the check engine light on?
sounds something like like a failing MAF sensor, or similar.
99 Camry V6 LE, 80k miles
eevee11 is offline   Reply With Quote
Old 09-12-2010, 02:14 AM   #3 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
4th Generation
i have the same problem with 4 cyl.
AliRazoR is offline   Reply With Quote
Old 09-12-2010, 07:41 PM   #4 (permalink)
USA
Thanks for the response.
Check Engine light came on 6 months back. I replaced a coil pack but there is no light now.
Could this be a dirty fuel injection problem? Should I try the fuel injection cleaner?
Thanks.
Tags
99 camry, cold start., starting trouble
