Hey guys,
So I'm back with one problem fixed and another problem to tackle. So I bought this car a few weeks back and although its been great to drive its also given me more problems then my other 96 camry. Anyways on with the issue.
My car was picked up without the AC working. After much investigation I had a mechanic hook up the Freon machine at which point my condenser literally started spewing out stuff and it was deemed to be a bad condenser. We reinstalled a brand new condenser, recharged the system and I was on my way with freezing cold AC again
However, about 2 days after this while sitting in traffic my car began overheating. I towed it to a friends house (toyota mechanic) and we realized my radiator fan was completely seized up. Needless to say we replaced the fan with a new one and we figured out that the fuse for the fan was also blown...replaced that with a 30 amp fuse. Now the car is not overheating anymore and the fan for the radiator engages when the car is idling, however my AC is no longer working now.
My question is, being the system for the AC wasn't working for a while before the condenser was replaced, could the overheating and fan issue have anything to do with my AC not working anymore or is this more likely to be a freon leak in the system? I had my mechanic put dye in the freon before recharging the system so hopefully if it's a leak it will be visible and be able to diagnose the problem further.
Can someone also give me insight about which fuses/relays to replace or check before spending more money on this AC issue?
Thanks
