Temperature Gauge Rises??? Please respond - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2010, 04:52 PM   #1 (permalink)
View angelpet's Photo Gallery
I have a 2000 Toyota Camry LE - 4cyl. I have a new radiator, new thermostat, new radiator cap, new temperature control sensor, new coolant, new radiator hoses. However, when I stop or in traffic for any length of time, the temperature guage goes up. It does come back down after I proceed / accelerate. It does NOT go up in the red section - just near it. What could be the problem? At a wits end with this...it was tested and thermostat is opening when it should & fans are operating. Please help me with a response. Thank you.
angelpet is offline   Reply With Quote
Old 09-12-2010, 05:00 PM   #2 (permalink)
View b2p1986's Photo Gallery
Sounds like you have the same problem I was experiencing. If you are only overheating at idle and when you begin driving it cools down then you simply have an issue with your rad fan. Check your fan to make sure like mine that it is not seized and still spinning. Do this when the vehicle is off and monitor it once you start the car. In the case of the fan being messed up, it may have blown a fuse and/or relay as well. Check to make sure the fan is working by a) jumping the relay in the fuse box near the battery. b) Unplug the temperature sensor on the botton of your radiator. This will ensure turn on the fans automatically. If they do not turn on it means your temperature sensor is not functioning.
Check your fans...
b2p1986 is offline   Reply With Quote
Old 09-12-2010, 05:24 PM   #3 (permalink)
I had the fans checked professionally at the garage. They said they were working like they should. Of course, it wasn't a Toyota garage though. They told me not to worry about the gauge fluctuating, but I do. It never did that before.
Old 09-12-2010, 05:26 PM   #4 (permalink)
How many sensors are on a 200 Camry le - 4 CYL?
Old 09-12-2010, 07:10 PM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Hook up a ODBII reader like Scangauge II or Ultra-gauge to read the coolant temp sensor (the one the ECU uses) vs yer analog gauge.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
The Following User Says Thank You to BamZipPow For This Useful Post:
angelpet (09-12-2010)
Old 09-12-2010, 07:14 PM   #6 (permalink)
View CWH5's Photo Gallery
Yes, Check your fan operation, check that it is blowing in the right direction, then also check that your A/C Condenser is not clogged up with bugs and road grime. You also did not mention if you replaced the water pump, the impellers in the pump can become corroded or rust off the ends slowing flow at low pump speeds.
You may want to also check that your gage is reading correctly, Should be about 1/2 at around 190 F.
CWH5 is offline   Reply With Quote
The Following User Says Thank You to CWH5 For This Useful Post:
Old 09-12-2010, 07:58 PM   #7 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Sounds like a dieing pump if the fans are working ok. Turn your ac on and see if the fans turning.
carsrus is offline   Reply With Quote
The Following User Says Thank You to carsrus For This Useful Post:
