My Camry needed a new water pump and radiator and was also leaking some oil on the passenger side. I thought the oil leak was from the oil pan but when I got the lower timing belt cover off during the water pump replacement, I realized it was the oil pump shaft seal and O-Ring. It took me a while but I followed two of the great threads here with photos and got everything installed! I even did my Crankshaft seal while I was in there because it came with the seal kit for the oil pump work!
I did run into one snag when I was reseating the water pump cover/housing and it is now haunting me! The O-ring in the back had fallen out while I was reinstalling it, I thought I reseated the O-ring but after I had tightened the water by-pass pipe nuts and a few of the water pump bolts, I noticed a piece of the ring was in the inlet, I removed the water pump and took the top nut back off the water by-pass pipe and when I was trying to remove the lower nut it stripped. I do not know if I pinched the O-ring in the process (I think I did now). After a good cry, I noticed I was able to still move the housing/cover around, I was back in business! and also thought I had once again got the O-ring in place and proceeded forward; installed the water pump, did the timing belt and timing, checked it and put the lower timing cover back on. It was time to start the engine and check the timing one last time before I went ahead and put the whole thing back together.
When I was filling the radiator and almost had a gallon in, coolant started free flowing out of the housing area. What should I do? Is it the O-ring? Did I miss something? I noticed the water pump came with a tapered head screw, did I not install a screw I was supposed to? Is there a pressure release that blew that I am not aware of? I am planning to take it apart again tomorrow. Hopefully I will be able to just buy the O-Ring?
This is my plan, please review it and advise me if I should go a different route or if I missed something mentioned above:
1. I am going to remark my timing belt and remove it, it should be an easy re-install and check on the way back. 2. I am going to remove the water pump bolts and the top water by-pass nut, move the entire cover/housing while keeping the pump attached and attempt to slip in a new O-ring and reassemble.
few other questions:
1. to test the timing, I can run the engine. Can that be done without the crank pully bolted in and the power steering belt attached?
2. can I use a few dabs of bearing grease to hold the water pump cover/housing O-Ring in place or will that botch the seal?
3. I was thinking a small pair of needle-nose vice grips would work to get the stripped lower by-pass pipe nut off, I was also thinking I could move the air-conditioner compressor out of the way to get more clearance? Are there any other suggestions to get the nut off? Can I replace the nut with a new one from the hardware store or do I have to buy one from the Toyota dealership or parts place?
4. Will I be able to buy just the O-ring or a gasket kit from the parts place or do I have to buy another water pump?
Thanks in advance for any help! -Joe
