Help with suspension questions...
I know these topics have been beat to death, but I am still have some questions and need some opinions.
Recently bought a 99 LE 4Cyl with 94k miles. The car overall is in great shape, but probably needs a few things due to age. I cannot tell for sure whether the car needs struts or not. The ride is definitely soft, but i cannot tell if this is the way it is supposed to be. When I push down on the rear corner, it goes down pretty easy and when it comes back up has like one little bounce. I know that new struts would probably make a big difference in ride, but do I really need them? Should the ride on my 99 Solara SLE V6 be the same as this camry? The Solara has alot more miles, but rides totally different. Do they have similar set ups?
Also, the rear sway bar bushings. Since they are cheap, i will probably just replace them. I do get a little thump noise when going over speed bumps. Not bad, but i do notice it. I think I may try this one myself. Based on the write ups i read, it sounds pretty easy.
What other suspension stuff should I check, both front and rear? I replaced the dog bone last week, and what a difference. The one I took out was not trashed, but it did have some cracks. The front mount seems to be O.K., atleast from what i can see.
I think the previous owner just replaced the EGR valve too, as the CEL light was on. Anything else you guys recommend checking on this vehicle besides the obvious (fluids, belts, hoses)?
So far, I am really liking this car!
