wierd problem with my 94 camry 4cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2010, 07:24 PM   #1 (permalink)
View matt bralich's Photo Gallery
only starts cold will run for 10-12 mins till warm. then turns off.wont restart till cooled off.not overheating runs smooth during that time.Tried new coil.no change.something on engine sensitive to heat??
matt bralich is offline   Reply With Quote
Old 09-14-2010, 09:07 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
no check light? / read the codes?
check fuses/ & maf/map
clean TB/iac
Old 09-15-2010, 09:40 AM   #3 (permalink)
View oldfirebird's Photo Gallery
I'd start basic. When it won't start, check for spark then check for fuel pressure at the rail. I've seen crank sensors stop working when they warm up and fuel pumps do the same.
oldfirebird is offline   Reply With Quote
Old 09-15-2010, 02:49 PM   #4 (permalink)
Gameroom cash: $303755
Since you already replaced the coil, I would next think about engine coolant temperature sensor, which can be checked with a digital volt/ohmeter and the specs from any manual. It may be out of range and is telling the computer the engine is always cold. This would result in a very rich mixture for a warm engine. Check it both cold and warm. If that checks out OK, I would next check fuel pump pressure both cold and warm. Weak fuel pumps have a tendency to go out when they heat up.
Mike
