battery display - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2010, 07:34 PM   #1 (permalink)
View netsfan549's Photo Gallery
battery display
The battery light keeps showing on dashboard but I just change battery;it is still showing. What else can it be?
netsfan549 is offline   Reply With Quote
Old 09-15-2010, 07:43 PM   #2 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
That light means the charging system is not working correctly. Make sure your alternator belt is adjusted correctly if that's not the problem, get your alternator checked.
Pvt-Public is offline   Reply With Quote
Old 09-15-2010, 08:57 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
I'm guessing your belt is worn and a little loose.
Chris Crash is online now   Reply With Quote
Old 09-16-2010, 02:44 AM   #4 (permalink)
Banned
Gameroom cash: $110000
View AliRazoR's Photo Gallery
check your alternator connectors.
AliRazoR is offline   Reply With Quote
Old 09-16-2010, 09:56 AM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
...and check your ground cable.
If none of that fixes it, most auto parts stores will test alternators for free. You just need to remove it and bring it to them.
BMR is offline   Reply With Quote
Old 09-16-2010, 10:18 AM   #6 (permalink)
V8'sRGone
73sport's Avatar
Gameroom cash: $307501
View 73sport's Photo Gallery
Would it be true that the times it came on were at idle, with the lights and heater on? If so, all those "check the belt" posts will likely be the correct answer as usually once the alternator fails (whether its the AC to DC bridge or the voltage regulator), they don't repair themselves so it looks like a belt or bad connection will likely solve your problem. . .
If you have a hand held meter multi-meter you can check it and get an idea of its voltage output too.
73sport is offline   Reply With Quote
Old 09-16-2010, 10:32 AM   #7 (permalink)
Banned
alternator test:
1)turn on the car
2)turn on AC and Head lights
3)remove the positive cable of battery
if your car stay on means the alternator is working
Old 09-16-2010, 12:50 PM   #8 (permalink)
Gameroom cash: $303755
Originally Posted by AliRazoR View Post
alternator test:
1)turn on the car
Do not do this test. This was an acceptable test in my youth (I did it myself back then, many many years ago.), but should not be done on today's modern engines. Todays' engines have some very sophisticated electronics. The voltage spikes created by disconnecting and/or reconnecting the battery cable on a running car can ruin some of those electronics. You may do this and the car will be fine, but you are taking a real chance, IMHO.
It would be better to take the alternator off and take it in to an auto parts store for a free check or drive the car there, if the car is running, as has been suggested above. You can also check the voltage output of alternator with a volt/ohmeter as has also been suggested. Just make sure you use a digital volt/ohmeter, not an old fashioned analog one, for the same reasons I mentioned in reference to pulling the battery cable.
Mike
