Originally Posted by jacobkk
Now I'm not sure what else to check,
Given it's a 96 you obviously have no trouble codes since you've made a good start at initial diagnosis. Even though I have a 95 there are some possibles that don't involve a code that might also be areas to check in the 96 which don't point to the IAC. I also assume you get normal engine operation above idle.
1. Possible TPS signal that is not off at idle position and may be causing slight flooding.
2. If you have a MAP that could also cause poor idle if malfunctioning.
I would also (carefully) see if spraying starting fluid or like while at low idle does the idle increase. That would show poor fuel delivery/excess air at idle.
I guess it's possible that a leaking EGR valve might cause poor idle (vacuum leak), but usually they cause stalling if stuck open. Is the idle rough or smooth?
Even though the IAC resistance may check out, if it is not opening fully you will get low(er) idle. You might try manually triggering the IAC without the ECM signal to see if you get better idle. If you are not getting a voltage signal from the ECM to the IAC that could also be the problem. My manual says it should get 9-14V.
