Engine gasket kit parts list for 5s-fe
I'm putting together a list of gaskets and seals in the gasket kit for a 5s-fe engine, along with any brand-specific variations from the standard list.
Here is what I have so far. Can anyone provide confirmation, or any additional parts?
Upper end / head gasket kit, $260 Toyota list, $35-$100 after market
11115-74081 Graphite cylinder head gasket $88.98/66.27
17177-74070 Intake manifold to head gasket 11.63/8.66
17173-74040 Exhaust manifold gasket 27.98/20.84
11213-74020 Valve cover gasket $13.19/9.83
90480-30025 Spark plug hole seal 4@ $4.37/3.43
11183-74010 Semi-circular "half moon" plugs, 2@ $7.00/5.50
90913-02066 Viton exhaust valve stem seals 8x $9.15/6.95
90913-02090 Viton intake valve stem seals 8x $5.12/3.89
90311-38067 Camshaft front seal $7.38/5.50
22271-74022 Throttle body gasket, four bolt holes 1.43/1.09
16341-74020 Water outlet gasket, squared-off, two bolt holes 3.37/2.65
25627-74011 Exhaust gas recirc pipe gasket: metal, two bolt holes $0.97/0.74
16258-74021 Heater return / water bypass: Two bolt holes w/ nubs 4.60/3.50
Other gaskets shown on the Toyota parts diagram
O-rings at fuel rail inlet, outlet and injectors
O-ring at water bypass
metal ring at exhaust manifold
Unidentified parts on after-market kit photos
Small O-rings 4x (injector o-rings?)
Three decreasing size and thickness o-rings
Additional round seals
Possible gaskets/o-rings that match the extra seals
90099-14091 Distributor housing o-ring 3.49/2.65
23232-41081 Fuel inlet hose gaskets, 2@ 1.91/1.45
90430-08014 Fuel return pipe gasket 2@ 1.17/0.89
90301-07001 Fuel injector o-ring, 4@ 3.00/2.28
96761-24017 o-ring at water bypass pipe 1.83/1.39
16325-63011 thermostat gasket at water inlet 5.23/3.97
12480-18001 PCV Valve grommet, $4.83/3.74
90430-37140 Oil filler cap gasket 2.00/1.57
Less likely parts -- likely in the lower-end gasket kit
90301-37005 water pump o-ring, large 2.34/1.78
90301-52002 large o-ring for oil cooler 4.37/3.32
15785-35010 small o-ring for oil cooler 1.20/0.91
Also needed
08826-00080 FIPG Seal packing 13.82/10.50
