Wiring Leds to Dome Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2010, 05:33 AM   #1 (permalink)
View G4LE00's Photo Gallery
4th Generation Wiring Leds to Dome Light
Ive been trying to wire my led strip to my dome light so they come on when the doors open. The only problem is, when I wire it to straight to the trigger/ the led comes on when the door is closed and turns off when its open.another problem was that the led gets dim when more than on door is open...
Did i tap into the wrong wire?
G4LE00 is offline   Reply With Quote
Old 09-19-2010, 06:37 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
What color(s) is the wire that you tapped into? Got piccies of what you did?
Which trigger are you talking about? The door switch is ground based...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 09-19-2010, 07:37 AM   #3 (permalink)
Dont have any pics, but its just one red/green wire coming straight out of the door switch. Was this the wrong wire to tap into?
Old 09-19-2010, 08:43 AM   #4 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
probably...there is a switch on the door that when it is open it engages the dome light...look on the back of your door jam and see if you can find the colors of that contact switch...then wire you leds to that and you should be good...
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 09-19-2010, 09:01 AM   #5 (permalink)
yeah, the red/green wire im talking about is coming out of the switch in the door jam. But it seems to work backwards, it turns on when the door is closed.
Old 09-19-2010, 11:40 AM   #6 (permalink)
jtex2717's Avatar
reverse the polarity...maybe that will do something...you have the light activating when the switch closes...and maybe if you reverse it then it will work when the switch opens...or...take the wire from the dome light itself and tap off of that...a little more work but it'll do the job...
IM BAAAAAACK!!!!!!!
