help with strut part numbers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2010, 11:07 PM   #1 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
hello fellow TN members
i am a bit puzzled.
i am about to order struts and am unsure which strut fits my car
on the tokico website it say camry VL10 yr 92-94 part# HZ3138
and
camry VL10 yr 94-96 part# HB3170 / HB3180
my chassis is MCV10L i think...
Vehicle info:
94 camry 1mzfe mcv10l
can both struts fit?
does anyone know if there is any difference between the HZ3138 and HB3170?
can somebody please help me
Old 09-20-2010, 12:47 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Here's the deal. 1994 is a weird year and got 2 different kinds of struts. Serviceable (the cartidges can be replaced) and non-serviceable (the entire strut has to be replaced). What you have right now doesn't matter since you're upgrading to tokicos. I do recommend getting serviceable struts though. If you happen to need a replacement in the future, a cartridge alone is cheaper than the whole strut. Not that it really matter with tokicos.... lifetime warranty and all. So yes, both types of struts will fit. I believe the HB's are serviceable... but DOUBLE CHECK. Hope that helps.
'07 Honda Ruckus Big Bore
Old 09-20-2010, 10:18 AM   #3 (permalink)
hey lynch thanks for the info.
i would love to get serviceable struts but i would think i would need the oem strut housing to go with the cartridge in the first place. i always try to change the struts when needed (every 50k miles or so) and i cant remember if i had serviceable in the beginning
so both struts fit without problem? i found both the HZ are waaay cheaper and the HB expensive.
and the HB are serviceable? that would be awesome if they are.... im sold,
i just dont want to buy a pair and turn out they dont fit...
any body have coil springs Fronts only for sale?
change ur mind on the springs lynch?
Old 09-20-2010, 12:55 PM   #4 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
If one is wayyy cheaper make sure you aren't buying just the cartridge for a serviceable strut though. I almost made that mistake when I ordered my struts online.
LittleWhiteBubble is offline   Reply With Quote
Old 09-21-2010, 05:21 AM   #5 (permalink)
Freakin Scooters
Both struts will fit without any problem. MAKE NOTE OF THIS: No one has ever tried to install tokico cartridges in a factory serviceable strut. I'm 75% sure the HB's are the serviceable ones... but like I said, DOUBLE CHECK. And no, I want to sell my springs as a set of 4.
edit: EVERY 50,000 MILES?!?!? What are you doing to your suspension to make it wear so fast?
