On my Camry I found a sticky gas pedal problem to be caused by the plastic pully; part of the cruise control hardware I think. It's under a plastic cover just left of the battery. I squirted some lube down at the pully's axle which fixed it. With the engine off, have someone press/letup on the accelerator repeatedly and lube anything that moves under there.
