I'm having trouble getting the distributor properly re-seated after replacing the O Ring on a 95 Camry. It's going in fairly easily until its about 3/16" (a hair more than the width of the O-Ring, so the O ring isn't preventing it from going in) out, then it refuses to go in any further. From the feel of wiggling the rotor it seems like the tabs are in end of the shaft. ( it wiggles slightly but won't turn. Also, if I manually crank the engine forward the rotor moves with the engine)
Has anyone seen this before? Is there some trick to this?
Any help would be appreciated!
This is a 4 cyl camry, btw.
