High Mil Oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2010, 05:33 AM   #1 (permalink)
View daddyrav's Photo Gallery
High Mil Oil
Can anyone tell me about high mile Oil? Good, bad?I got several oil leaks, will that help the leaks?
daddyrav is offline   Reply With Quote
Old 09-27-2010, 06:01 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Where are yer oil leaks? If it's the valve cover gasket, yer better off just replacing the spark plug tube grommets and the valve cover gasket. Just make sure yer using sealant at the proper places and only a small dab.
Post up some piccies of yer leaks.
High mileage oil usually isn't worth the time...it's all about the marketing.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 09-27-2010, 09:20 AM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
High mileage oil isn't bad, but it takes a couple of oil changes to expand the seals. I would not expect it to work much of a miracle on an already leaking seal. Like bamzippow said, I would change the seal rather than get hm oil...
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 09-27-2010, 12:39 PM   #4 (permalink)
Thank you, i will try that
Old 09-27-2010, 02:00 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
fix the leaky seals if they are the easy ones (valve cover?).
HM oil is not really anything better over classic oil IMO ... it's got some additive which slowly expands seals, not worth its price if you change oils frequently if you ask me. never used HM oils on any of cars.
Old 09-27-2010, 11:44 PM   #6 (permalink)
on full afterburner
Gameroom cash: $1339697
If you're burning oil, yes high mileage oils will help.
But if you're leaking? That's anyones guess. More likely not since you have a different problem altogether.
