Toyota ATF the best? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2010, 08:18 PM   #1 (permalink)
View importcar's Photo Gallery
Is Toyota ATF specially formulated for our cars? Or can I use any other Dexron III ATF? I will be doing a drain and fill for the tranny and differential but I'd like to know if I can use something else besides the red yota atf.
2001 Camry LE 5S-FE
importcar is online now   Reply With Quote
Old 09-28-2010, 08:36 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260040
View Yuko's Photo Gallery
On my 2001 Camry, I used Valvoline Dex/Merc ATF and Maxlife in the diff, feels the same which a good thing. Some say the Type-IV is backward compatible but I wouldn't mess with it. The only time I used Type-IV are for newer transmissions that requires it.
I went ahead and drop the pan to change the strainer, it's about $10 for strainer and gasket at Napa. These two DIY below helped me a lot.
DIY: 1996 Camry Transmission Fluid & Strainer Replacement by dz63
DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
DIY : Differental Fluid Change by Maim Menu
Yuko is offline   Reply With Quote
Old 09-28-2010, 08:46 PM   #3 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Toyota ATF is not the best. It might be the opposite as typically, the order goes to the lowest bid from whatever company's product meets the required bid spec.
I always use full synthetic. Since Dex/Merc is not a licensed spec anymore, a great upgrade for those that can't budget Amsoil, Redline, Mobil1, or Royalpurple... is ANY Mercon-V.
deadrx7conv is offline   Reply With Quote
Old 09-28-2010, 09:53 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
another good one is between Mercon-V and synthetic ATF is a Castrol Import Multi Vehicle ATF (synthetic blend), it's around $4ish per 1qt. Better than both Dexron-III and Mercon-V, still at less price than what you pay for any synthetic ATF out there.
I'd love to have Royal Purple ATF, but their price of $13/qt kind of repels me
Old 09-28-2010, 10:13 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Toyota ATF is the best if you are a dealer making profit off of it. Otherwise... buy a good name brand and be happy.
Zembonez is offline   Reply With Quote
Old 09-28-2010, 10:29 PM   #6 (permalink)
Since a drain and refill replaces only 50% fluid in the tranny, is it safe to mix other brands with the yota fluid?
btw, are all ATF red?
2001 Camry LE 5S-FE
Old 09-28-2010, 10:59 PM   #7 (permalink)
Yes, its safe to mix.
Old 09-29-2010, 05:52 AM   #8 (permalink)
I wrench, therefore I am!
Gameroom cash: $213700
View TedL's Photo Gallery
If you're that interested, I'm pretty sure I saw it for under $9 at Pep Boys the other day.
While mixing is Ok, why not flush to get a complete change? It'll take 12-15 qts.
Since my three family Toys list Dexron as an alternative, I've upgraded to Dex VI in all of them. Excellent performance, especially shifts.
TedL is offline   Reply With Quote
Old 09-29-2010, 11:06 AM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, flushing with like 12qts should make it almost all new fluid in tranny.
in my 4cyl Solara I flushed the tranny after dropping pan and changing strainer. Used Castrol Import MV ATF, but used only like 3qts for flushing after transmission and differential refill hehe, so ended up probably with like 75% new fluid (I hope).
Now thinking what to do with 1mz-fe, because I haven't flushed it yet, only drained, refilled 2 times (Castrol IMV ATF) and dropped pan for cleaning and changing strainer last time.
the cooler line is hard to access (and hose is stuck) ... so I may need to remove the rad fan to get better access for hose removal... will definitely be flushing it with something, but I think I will stick to cheaper synthetic blend (Castrol) than full synthetic ATF products ... it gets a tad expensive when using 8-10qts, not even mentioning it should be done with like 12-15qts ...
$9/qt doesn't sound too terrible, will check my local Pep Boys for this deal, IIRC Advace Auto had it at $13/qt
on the other hand RP motor oil is cheapest around here in Advance AUto at $8.50 while NAPA has it for like $10/qt (PB had it for like $9ish/qt)...
Old 09-29-2010, 03:29 PM   #10 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Most brand named DEX III compatible/approved/meets specification will be good.
Mobil 3309 is the Toyota T IV exclusive, so unless the owner's manual or dip stick says Type T IV, I would just use a Multi vehicle or DEX III / Mercon V fluid.
I personally have been using Valvoline Dex III/Mercon in my two Camrys because it is the lowest cost, but not store brand fluid. Previously I used Petro-Can because it was conveniently supplied to my job site.
Fenixus- remove hose from transmission.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 09-29-2010, 03:33 PM   #11 (permalink)
抵抗は無駄です
fenixus's Avatar
that's what i tried doing, bt this bastard is stuck on the steel pipe
need to play around with it and get it loosened somehow. hard to twist it around with little clearance for my first down there.
Old 09-29-2010, 07:48 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
All Dexron type ATFs are red as specified by GM. Some ATFs are clear/amber.
Your 01 Camry is the last year with the Aisin A140 series transmission. Which is more reliable than the newer U-series clunkers out there. This transmission will work fine with dino Dexron like the Walmart SuperTech for about $11/gallon (this was like $9 months ago). Better fluids, like others said, are Mercon-V (SuperTech for example), Castrol IMV, Mobil-1, etc. When getting Mercon-V, make sure you get the new formulation that's suitable for D-II/III and not some old bottle on the shelf. But just about all multi-vehicle ATFs these days are D-II/III compatible.
Your 05 Sienna has the U151E (FWD) or U151F (AWD) Aisin "clunker" as I call them. This should take the T-IV (Mobil 3309) dino ATF. The Toyota T-IV is considered an inferior fluid that turns brown in as little as ~20K miles according to BITOG discussions. Castrol IMV, Valvoline MaxLife, Mobil-1 or other fluids suitable for T-IV should all be better.
I however would not use Dexron VI in these transmissions. The D-VI is a very thin fluid and had some problems with older GM Hydramatics that were better off on thicker D-II/IIIs. So I'd use D-VI only in the new (and excellent) Hydramatic transmissions designed for it.
The Following User Says Thank You to JohnGD For This Useful Post:
71Corolla (09-30-2010)
Old 09-29-2010, 07:50 PM   #13 (permalink)
BTW the U series should be using felt type filters. These should be replaced 15-30K miles as they can plug up with time.
The A series use a strainer without real "filtering" function.
Old 09-29-2010, 09:08 PM   #14 (permalink)
I bought 4 qts of SuperTech High Mileage ATF because my Camry has 160K miles. Does that make a difference or would I be better off getting Mercon V or regular Dex III ATF?
I thought Toyota ATF was specially formulated because it stays red for thousands of miles. My last drain and refill was at 123K and the fluid is still red.
2001 Camry LE 5S-FE
Old 09-29-2010, 09:26 PM   #15 (permalink)
High Mileage ATFs usually have a slightly thicker viscosity for better wear protection, some seal conditioners and maybe more cleaner. So that should be fine. Many here use Valvoline MaxLife ATF. I personally don't go the High Mileage route unless there are some minor problems I try to solve.
The most important thing is to make sure the label says suitable for your specific application.
The price of dino ATF is not that much cheaper than SuperTech Mercon-V. But Mercon-V can stand the heat better and is more shear stable. This ATF is certified by Ford to the new tightened standard, so Mercon-V certified fluids are quite consistent across brands. It's also a good fluid for the PS system.
