Camry whistles on acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2010, 03:46 PM   #1 (permalink)
View Gamble's Photo Gallery
My brothers camry has been doing this for awhile. I changed this throttle body gasket and isc gasket and there are no vacuum leaks in the inlet tube. I sprayed down all the vacuum ports trying to see if the idle would increase and nothing. So last thing is the intake manifold gasket is my guess.
Anyone have a write up on this and about how long it takes to change? It doesn't look fun.
Even with the car running under the hood if you blip the throttle you can hear a leak but can't pinpoint it.
Gamble is offline   Reply With Quote
Old 09-30-2010, 04:19 PM   #2 (permalink)
Forum Manager
administrator's Avatar
Gameroom cash: $145750
View administrator's Photo Gallery
Is it running well? Generally if you have a bad vacuum leak that you can hear, it will run like crap.
Nadeem
administrator is offline   Reply With Quote
Old 09-30-2010, 04:50 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
The grommet on the PCV deteriorates and whistles.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 09-30-2010, 06:38 PM   #4 (permalink)
Could the pcv only whistle while on the gas? Here is the odd part, it runs perfect.
Old 09-30-2010, 09:54 PM   #5 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Have you checked its not the idler bearings/tensioner or a broken intake pipe or somewhere in the air filter?
Does it whistle only when moving or even while stationary?
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 09-30-2010, 10:03 PM   #6 (permalink)
View camryguy96's Photo Gallery
well seeing as the pcv valve is here in this conversation does the 1996 with cali emisions have pcv valves if so where is it located
camryguy96 is offline   Reply With Quote
Old 10-01-2010, 07:43 AM   #7 (permalink)
idler bearing and tensioner was all replaced. I looked at the intake pipe and it all looks ok. I can't hear it when sitting still only while moving. The whistle sound that is. But when you blip the throttle and your head is under the hood you can hear a vacuum leak.
And the pcv valve turned out to suck ass last night. The rubber grommet cracked and fell in. So I had to take off the valve cover and get a few pieces out.
Btw the pcv is $13 from the dealer and the grommet was $7. A little pricey for these things.
If it's the same engine which I think it is, it's on the valve cover between spark plug wires 2 & 3.
Old 10-01-2010, 09:07 AM   #8 (permalink)
I wrench, therefore I am!
Gameroom cash: $213700
View TedL's Photo Gallery
That's from the dealer near you, who appears to be charging 150% of list for those parts. That's more than double you'd pay to sponsor Toyota of Newnan, which charges 70% of list.
OP: You need to help us help you. The car comes with a 4 or 6; you didn't tell us which he has.
TedL is offline   Reply With Quote
Old 10-01-2010, 10:43 AM   #9 (permalink)
Oh sorry 4cyl auto
Old 10-01-2010, 10:51 AM   #10 (permalink)
A camry n00b
peshwa's Avatar
Wow thats expensive from a dealer. I changed out my 15 year old PCV valve and grommet weeks ago for $5 in total. $tealerships are not notorious for nothing...ha ha
Old 10-01-2010, 01:42 PM   #11 (permalink)
Still has the whistle after the pcv change
Old 10-01-2010, 02:02 PM   #12 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
Its maybes yous has Turbos...
Im sorry I know bad joke...Did you check all of the vacuum hoses that run off the throttle body? I know on the 5s auto there are a lot of these little lines and if they arent new then I would start there...
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 10-01-2010, 02:19 PM   #13 (permalink)
Check all around the intake and plenum with carb cleaner. Use a length of hose to your ear as a stethoscope to locate the sound.
R&R the intake is a good bit of time & money for a guess. Logically, a leak there should be evident at idle, when the vacuum is higher. When you open the throttle, vacuum drops in the intake manifold, but increases in certain ports from the throttle body. I'd look at those connections & hose, all the way out to their other end. Which could be a blown diaphragm.
